{getmodule 103}
TEMAT: Kia Cee'd SW 2011 automat U5YHB812BCL199741
Kia Cee'd SW 2011 automat U5YHB812BCL199741 2014/03/06 12:06 #57937
  • reme_k
  • reme_k Avatar
proszę o sprawdzenie Kia Cee'd SW 2011 automat
Vin: U5YHB812BCL199741 Sprawdź ten VIN na autobaza.pl ▸
przebieg : 106 458 km
miejscowość: Izabelin k. Warszawy
otomoto.pl/show?id=C32397302
Kia Cee'd SW 2011 automat U5YHB812BCL199741 2014/03/08 01:38 #58083
GDzies juz ten sprzedawca byl u nas na forum i nie mial samochodu dobrego tylko cos bylo nie tak
U5YHB812BCL199741
U5YHB812BCL199741
Slovakia
381;ilina
KIA
Ceed 10
WAGON - 5DR 5P
Skrzynia biegów:
automatic
Napęd:
FWD
CEED 10 MODEL (2010 -) [SEURPED10]
ENGINE CAPACITY:
1600 CC - GAMMA
DOHC - MPI
BODY:
WAGON - 5DR 5P
GASOLINE - UNLEADED
AUTO - 4 SPEED 2WD
22/03/2011
AREA CODE:
C51 - EUROPE
C27 - POLAND
COLOR CODE INTERNAL FINISHES:
EQ
CODE Exterior:
1K
WT 2:
COLD ZONE
0091A4:
ENGINE PACKAGE - CVVT ENG
2111A2:
ENGINE GASKET - NON ASBESTOS
2531A2:
RAD CORE MATERIAL - NOT RESISTANT CACL2
2841B7:
EMISSION REGULATION - EURO 5
2843A2:
EVAP. GAS CONTROL - EURO-3
2861A2:
MUFFLER MAIN ASSY - SINGLE-CR COAT"G
2891E1:
CATALYTIC CONVERTER - W.C.C
2921A2:
ENGINE COVER - SEMI
3111B3:
FUEL TANK-CAPACITY - 53 LITER
327AA1:
KICKDOWN MECHANISM
3521B1:
ETC TYPE
BATTERY SAVER
3711A4:
BATTERY CAPACITY - 36AH (5HR)
3921A2:
SENSOR-AIR FLOWER - SPEED DENSITY
4371B1:
AT KNOB - SOFT PVC
4503A2:
SHIFT LOCK SYSTEM - ELECTRONIC TYPE
4509A2:
GATE TYPE
529AB1:
TIRE PRESSURE LABEL - EUROPE
5291B5:
STEEL WHEEL - 5.5J * 15
5294B1:
TIRE SOURCE - MICHELIN
5295A3:
TIRE MATERIAL - LRR
5296C1:
FULL SIZE WHL COVER - A TYPE
5297C1:
TEMPORARY - STEEL WHEEL & TIRE
FR SUSP TYPE - MACPH. WithCOIL SPRING
S/ABSORBER TYPE - GAS
5511B1:
RR SUSP TYPE - MULTI LINK-NORMAL
5611B2:
3-SPOKE - POLY URETHANE
5631A4:
STEER"G COLUMN-MANUAL TILT & TELESCOPIC
569BB9:
PASS"S - POLAND LANGUAGE
569EA1:
PAB ON/OFF SWITCH
5691A3:
DRIVER SIDE - DEPOWERED
5692A3:
PASSENGER SIDE - DEPOWERED
5693A1:
SIDE AIR BAG-FR - FR(THORAX)
CURTAIN A/BAG
5711A6:
MDPS
5811A4:
FR BRAKE - DISC-15 INCH
5812A7:
RR BRAKE - DISC-14 INCH
ABS (ANTI LOCK BRK SYS)
5895A1:
BAS(BRAKE ASSISTANT SYSTEM)
5911A3:
SINGLE BOOSTER - 10 INCH
HIGH GRADE
813AA1:
SPEED SENS"G AUTO DR LOCK
IMPACT SENS"G AUTO DR UNLOCKG
813DA1:
IGN KEY REMINDER
8131A2:
CENTRAL DR LOCK/UNLOCK-DR"S & PA"S CTRL
8135A2:
INSIDE HNDL OVER RIDE - DR"S & PA"S SIDE
8136A1:
CHILD SAFETY RR DR LOCK"G
8152A3:
FUEL FILLER DR REL TYPE - CABLE
817AB3:
TAIL GATE FINISH"G-FORMED TYPE(PLASTIC)
8176A1:
TAIL GATE O/SIDE HANDLE - NATURAL COLOR
8177A1:
CENTRAL T/GATE LOCK/UNLOCK
822AA1:
DR BLACK OUT MATERIAL - TAPE
DR FRAME MLDG - BLACK
8226A2:
DR BLACK OUT FINISH - NON-BRIGHT
8232A3:
UPR TRIM FINISH"G - PVC
8235A1:
MAP POCKET FINISH"G - Without T/C PILE
8237A1:
ARM REST HANDLE - PULL TYPE
FR DR GLASS - TINTED
8245A2:
RR DR GLASS - TINTED
FINISH"G - BODY COLOR
8341A1:
POWER WINDOW(FR)
8349A1:
SW ILLUMINATION(ALL)
842BA1:
FOOT REST - METAL
8421D4:
N/PUNCH - STD
845BA1:
With ILLUM
8451A1:
Without LOCK
8452A2:
With DAMPER
846EA1:
POWER OUTLET
8462A1:
CUP HOLDER - FR(Without ILL)
8481A6:
GRAIN - METAL PAINT
85AGA1:
LUGGAGE SIDE BOX
85APA1:
TOOL CASE(OVM TOOL)
8511B1:
DAY/NIGHT TYPE
TICKET HOLDER
VANITY MIRROR COVER
852GA1:
VANITY MIRROR - GLASS TYPE
VANITY MIRROR COVER
8521A1:
MATERIAL - VINYL
8522A1:
8523A1:
MATERIAL - VINYL
853AA2:
RR - 2 EA
853JA1:
RR - 1 EA
8531A2:
ROOF TRIM MATERIAL - FABRIC
8532A1:
FR - 1 EA
857AA1:
POWER OUTLET
857HA1:
LUGGAGE UNDER FLOOR BOX
8571C1:
LUGGAGE SIDE - WithPAPER
8572A2:
RR - PLASTIC
8573A2:
FLOOR - WALL PAPER
8577A1:
CARGO SECURITY SCREEN
LUGGAGE NET HOOK
8611B1:
WithS GLASS TYPE-TINTED (Without S/BAND)
MLD"G-WINDSHIELD - BLACK
863CA1:
GRADE - GL
8631A1:
A" TYPE - BLACK
TOWING HOOK
TIE DOWN HOOK(LASHING)
8643A1:
SHIPPING HOOK
8651B1:
TYPE - 2.5 MILE
8652B1:
COLOR - BODY COLOR
8672A1:
ROOF RACK
8681A1:
MUD GUARD-FR
8682A1:
MUD GUARD-RR
RR HEATED With TIMER
8711A1:
MLD"G-BACK LITE - BLACK
BACK LITE GLASS TYPE- TINTED(With HEATED)
8722A4:
H.M.S.L - T/GATE OTR
8731B1:
MLD"G - BODY COLOR
877BA1:
RR DEFLECTOR
8791B1:
RR QTR GLASS TYPE - TINTED
8811C1:
CLOTH - CLOTH
8821A1:
HEAD REST - UP/DOWN
SLIDING
DOUBLE RECLIN"G
885DA1:
SLIDING
885EA2:
DOUBLE RECLIN"G
8854A1:
HEAD REST - UP/DOWN
888AA1:
PRE TENSIONER - MECHANICAL TYPE
888DA1:
SEAT BELT REMINDER
LOAD LIMITER
888GA1:
BUCKLE PRE TENSIONER
888KA2:
S/BELT ANCHOR - ADJUSTABLE
888PA1:
888RA2:
DRIVER"S SIDE - ELR
PASSENGER"S SIDE - ELR
8885A1:
RETRACTOR PRETENSIONER - MECHANICAL TYPE
8889A1:
SEAT BELT REMINDER
LOAD LIMITER
8912D4:
6:4 SPLIT BACK FOLD"G - CUSHION+BACK
8913A1:
LH
8914A1:
RH
8915A1:
CTR
HOLDER - UPR ANCHOR
LWR ANCHOR
898JA1:
S/BELT REMINDER
8981A4:
SIDE - ELR
8982A4:
CTR - ELR
9119A2:
JUNCTION BOX LABEL - ENGLISH LANGUAGE
921BA1:
LEVELING DEVICE - MANUAL
PROJECTION-LOW BEAM-A TYPE
9222A1:
RR - CONVENTIONAL
923DA1:
ONE TOUCH TRIPLE TURN SIGNAL
9232A1:
CONVENTIONAL - CLEAR LENS
9241A2:
NON LED TYPE
928FA1:
CTR - GLOW LAMP
928HA2:
FR - REFLECTOR
LUGGAGE LAMP
94C1A1:
A/T POSITION INDICATOR
DIRECTION INDICATOR
OIL PRESSURE
BRAKE OIL
PARK"G BRAKE
DR AJAR - DR AJAR
BATTERY CHARGE
HIGH BEAM
LOW FUEL
94D5A1:
RR FOG LAMP
TRUNK LID(T/GATE) OPEN
CHECK ENGINE
SEAT BELT
94E5A1:
A.B.S
A/BAG
94G4A1:
FOG LAMP (FR)
IMMOBILIZER
94M0A1:
SPEEDOMETER TYPE - KMPH
94N0A1:
TEMPERATURE UNIT - C
94W1A1:
TAIL LIGHT
940AA2:
TRIP ODOMETER - ELEC.
TACHOMETER
FUEL
WATER TEMP.
940EA1:
LCD ODO/TRIP METER
9401C1:
CLUSTER TYPE - CONVENTIONAL
SPEEDOMETER
BODY CONTROL MODULE - BCM(ETACS)
IMMOBILIZER
9545A3:
FREQUENCY-SMART KEY - GENERAL
9611NG:
RADIO+CD+MP3+RDS - PA 710R
9614B1:
COMPONENT- 2 DIN
9615A3:
FREQUENCY VIBRATION - AM9K/FM50K
9618A1:
USB+AUX
9621K1:
ANTENNA TELESCOPIC - ANTENNA MICRO
SPEAKER LOCATION FR DR - GENERAL
963ZA1:
SPEAKER LOCATION RR DR LOW-GENERAL
9651A2:
TYPE - INTERGRATED TYPE
9661A1:
HORN - SINGLE
967AA1:
AUDIO REMO.
9681A1:
SEAT BELT
9684A1:
KEY OPERATED WARN"G
9711A2:
BLOWER - 4 SPEED FAN
FUNCTION - AIR FILTER
9721B1:
ELEC TYPE - ROTARY TYPE
9741A1:
RR HEATING DUCTS - 2ND SEAT
FR WIPER-2 SPEED
981BA1:
FR WIPER-TIME ADJUSTER
FR WIPER - INTERMITTENT(VARIABLE)
9817A1:
MIST FUNCTION
9871A1:
RR WIPER - INTERMITTENT(NON VARIABLE)
5293EH:
195 TIRE - 195/65 R15
813MA1:
SECURITY INDICATE
KEYLESS ENTRY-B/ALARM
8194B3:
TYPE - FOLDING
834CA2:
SAFETY WINDOW - FR DR
84FAA1:
RR(Without ILL)
8441A3:
FR - ASH TRAY With ILLUM
8445A2:
CIGAR LIGHTER - With ILLUM
845DA1:
GLOVE BOX-COOLING
846BA2:
With STORAGE BOX ARM REST - DLX(2 DIN)
8461B1:
DLX - PVC
8762C4:
PASS"S SIDE - ELECTRIC HTD-CONV
8763C7:
DRIVER"S - ELECTRIC HTD-CONV(WIDE)
COLOR - BODY COLOR
ACTIVE HEAD RESTRAINT
8825A4:
ADJUSTER - PUMP"G DEVICE
8828A1:
LUMBAR SUPPORT - MANUAL LUMBER SUPPORT
8857A2:
ADJUSTER - HEIGHT ADJUSTER
8863A1:
LUMBAR SUPPORT
9221F1:
SPORTY TYPE - MFR
9282A1:
FR - With SUNGLASSES
RHEOSTAT
9552A2:
BLUE TOOTH (AUDIO)-With VOICE RECOGNITION
961DA1:
USB+IPOD
963MA1:
SPEAKER LOCATION QUADRANT INR COVER
967EA1:
BLUE TOOTH REMO
9761A1:
FR COOLER - MANUAL A/CON
