{getmodule 109}​​​​​​
TEMAT: Hyundai Genesis GENESIS COUPE
Hyundai Genesis GENESIS COUPE 2014/03/30 10:38 #59321
  • PagerOwski
  • PagerOwski Avatar
Witam serdecznie. Prosiłbym o rozkodowanie samochodu o nr vin KMHHT61DABU051018 Sprawdź ten VIN na autobaza.pl ▸ . Link do aukcji: otomoto.pl/hyundai-genesis-genesis-coupe-C31710708.html
Hyundai Genesis GENESIS COUPE 2014/03/30 14:29 #59327
KMHHT61DABU051018
KMHHT61DABU051018
South korea
Ul-San
HYUNDAI
coupe
Genesis Coupe (2008-) [KEURPDK08]
DOHC - TCI/MPI
BODY:
COUPE - 2DR 4P
ENGINE TYPE:
2000 CC - THETA FR
GASOLINE - UNLEADED
MANUAL T/M - 6 SPEED 2WD
KMHHT61DABU051018
15.10.2010
AREA CODE:
C51 - EUROPE
C02 - BELGIUM
COLOR CODE INTERNAL FINISHES:
9P
CODE Exterior:
NAA
WT 3:
TEMPERATE ZONE
0101A8:
MODEL YEAR PACKAGE - 11MY
2531A2:
RAD CORE MATERIAL - NOT RESISTANT CACL2
2841B7:
EMISSION REGULATION - EURO 5
2843A6:
EVAP. GAS CONTROL - LEV-2
2861B3:
MUFFLER MAIN DUAL BLACK PAINT+CR COATG
2865A2:
MUFFLER MATERIAL - SUS
2891C1:
CATALYTIC CONVERTER - W.C.C+U.C.C TYPE
3111C4:
FUEL TANK-CAPACITY - 65 LITER
BATTERY SAVER
3711A9:
BATTERY CAPACITY - 54AH (5HR)
3921A2:
SENSOR-AIR FLOWER - SPEED DENSITY
4911A2:
PROPELLAR SHAFT - TWO PIECE
4951D9:
LH/RH - VL3300I+VL3300I
529AB1:
TIRE PRESSURE LABEL - EUROPE
5291U1:
AL WHEEL 8.0J*19 : 8.5J*19 - A TYPE
5293HD:
225 TIRE - 225/40 R19 : 245/40 R19
5294B4:
TIRE SOURCE - BRIDGESTONE
5297E1:
AL WHEEL & TIRE (4.0T*18 T135/80R18)
FR SUSP TYPE - MACPH. WithCOIL SPRING
S/ABSORBER TYPE - GAS
5416A1:
STRUT TOWER BAR
5511B2:
RR SUSP TYPE - MULTI LINK-SPORTY
5531A2:
TUN'G MODE - HARD SUSPENSION
5631A3:
STEER'G COLUMN-MANUAL LWR TILT
569BD1:
PASS'S - A LANGUAGE
5691A3:
DRIVER SIDE - DEPOWERED
5692A3:
PASSENGER SIDE - DEPOWERED
5693A3:
SIDE AIR BAG-FR - FR(THORAX & PELVIS)
CURTAIN A/BAG
5711A2:
HPS(HYDRAULIC POWER STRG)
581AA2:
DISC SPEC - EUROPE TYPE
5811A7:
FR BRAKE - DISC-18 INCH
5812A9:
RR BRAKE - DISC-16 INCH
ABS (ANTI LOCK BRK SYS)
ESC (ELECTRONIC STABILITY CONTROL)
5911B4:
TANDEM BOOSTER - 7+8 INCH
5971A1:
PARKG BRK CONTROL - HAND TYPE
HIGH GRADE
8112A2:
HOOD OPENING DEVICE - GAS LIFT
812AA1:
T/LID EMERGENCY RELEASE
8122A2:
TRUNK LID OPENING DIVCE - GAS LIFT
8124A1:
TRUNK LID TRIM - FULL COVER
8125A2:
T/LID INSIDE HANDLE - HOOK TYPE
813AA1:
SPEED SENS'G AUTO DR LOCK
IMPACT SENS'G AUTO DR UNLOCKG
813MA1:
SECURITY INDICATE
8131A1:
CENTRAL DR LOCK/UNLOCK - DR'S CONTROL
8135A2:
INSIDE HNDL OVER RIDE - DR'S & PA'S SIDE
8152A4:
FUEL FILLER DR REL TYPE - ELECTRIC
KEYLESS ENTRY-B/ALARM
8195A2:
IGNITION ILLUMINATED - LED TYPE
82A5A1:
DR FRAME MLDG - BLACK
8231B2:
FORMED TYPE - DLX
8232A4:
UPR TRIM FINISH'G - ARTIFICIAL LEATHER
FR DR GLASS - TINTED
FINISH'G - BODY COLOR
834CA2:
SAFETY WINDOW - FR DR
834DB2:
AUTO UP & DOWN - FR DR
8341A1:
POWER WINDOW(FR)
8347A1:
SW ILLUMINATION(DR)
84L3A1:
A/T INDICATOR
8421E1:
T/C PILE - CARPET_STD
846BA1:
With STORAGE BOX ARM REST - STD(1 DIN)
846LA3:
CONSOLE COVER - ARTIFICIAL LEATHER
846NA1:
POWER OUTLET
8462A1:
CUP HOLDER - FR(Without ILL)
85ACA1:
TRUNK LID INR TRIM - WALL PAPER
85APA1:
TOOL CASE(OVM TOOL)
TICKET HOLDER
VANITY MIRROR COVER
852DA1:
ILLUMINATED
852EA1:
TYPE - EXTENSION
852GA1:
VANITY MIRROR - GLASS TYPE
VANITY MIRROR COVER
852KA1:
ILLUMINATED
8521A3:
MATERIAL - CLOTH(STD)
8522A1:
8523A3:
853JA2:
RR - 2 EA
8531A3:
ROOF TRIM MATERIAL - CLOTH(STD)
8561A2:
RR P/TRAY MATERIAL - WithPAPER
8571C1:
LUGGAGE SIDE - WithPAPER
8572A3:
RR - WALL PAPER
8573A2:
FLOOR - WALL PAPER
LUGGAGE NET HOOK
858AA5:
A PILLAR - CLOTH
WithS GLASS TYPE-TINTED (With S/BAND)
MLD'G-WINDSHIELD - BLACK
863CA1:
GRADE - GL
8631A1:
A' TYPE - BLACK
TOWING HOOK
TIE DOWN HOOK(LASHING)
8649A5:
ID PLATE - EUROPE('E' MARK) TYPE
8652B2:
COLOR - BODY COLOR + CR MLDG
RR HEATED With TIMER
8711A1:
MLD'G-BACK LITE - BLACK
BACK LITE GLASS TYPE -TINTED(With HEATED)
876MA1:
ELECTRIC FOLD'G CONTROL
876NA1:
SIDE REPEATER LAMP (O/S MRR)
876PA1:
MIRROR O/SIDE - EUROPE TYPE
COLOR - BODY COLOR
8772B1:
MLD'G-S/SILL - BODY COLOR
8821A3:
HEAD REST - UP/DOWN & TILT
SLIDING
DOUBLE RECLIN'G
8828A1:
LUMBAR SUPPORT - MANUAL
8854A3:
8866A1:
WALK IN DEVICE - WALK IN DEVICE
PRE TENSIONER - ELECTRICAL TYPE
LOAD LIMITER
DRIVER'S SIDE - ELR
PASSENGER'S SIDE - ELR
8885A2:
RETRACTOR PRETENSIONER - ELECTRICAL TYPE
LOAD LIMITER
8912L3:
FOR 2 PEOPLE - BENCH-FOLD'G
HOLDER - UPR ANCHOR
LWR ANCHOR
8981A4:
SIDE - ELR
921BA1:
LEVELING DEVICE - MANUAL
PROJECTION-LOW BEAM-A TYPE
9222A1:
RR - CONVENTIONAL
9245A1:
LAMP TYPE - INTEGRATED
928HA2:
FR - REFLECTOR
928WA2:
BULB TYPE - 2 BULB
9286A1:
GLOVE BOX LAMP
LUGGAGE LAMP
9297A1:
With MAP LAMP
9298A1:
With SUNGLASS BOX
DIRECTION INDICATOR
OIL PRESSURE
BRAKE OIL
PARK'G BRAKE
DR AJAR - DR AJAR
BATTERY CHARGE
HIGH BEAM
LOW FUEL
TRUNK LID(T/GATE) OPEN
CHECK ENGINE
SEAT BELT
A/BAG
94G0A1:
WASHER FLUID WARN'G LAMP
IMMOBILIZER
E.S.P
94M0A1:
SPEEDOMETER TYPE - KMPH
94N0A1:
TEMPERATURE UNIT - C
940AA3:
TRIP ODOMETER - LCD
TACHOMETER
FUEL
WATER TEMP.
9401C1:
CLUSTER TYPE - CONVENTIONAL
SPEEDOMETER
TYPE - DIGITAL
RHEOSTAT
BODY CONTROL MODULE - BCM(ETACS)
IMMOBILIZER
9545A1:
FREQUENCY-SMART KEY - DOMESTIC
961AA1:
AUX
9614B1:
COMPONENT- 2 DIN
9615A3:
FREQUENCY VIBRATION - AM9K/FM50K
9616A1:
VOLUME KNOB TYPE - EUROPE TYPE
9621E1:
GLASS ANTENNA - RADIO
SPEAKER LOCATION FR DR - GENERAL
963GA1:
SPEAKER LOCKTION RR QTR - GENERAL
963KA1:
SPEAKER LOCATION TWEETER-FR DR UPR
965KA1:
AUDIO DISPLAY
9661B1:
DUAL HORN - DISK TYPE
9681A1:
SEAT BELT
9684A1:
KEY OPERATED WARN'G
FUNCTION - AIR FILTER
972DA1:
O/SIDE TEMPERATURE GAUGE
FR WIPER-2 SPEED
FR WIPER - INTERMITTENT(VARIABLE)
9817A1:
MIST FUNCTION
9819A1:
BLADE TYPE - CONVENTIONAL
0094A2:
COLOR PACKAGE - TYPE 2
3281A3:
PEDAL TYPE - METAL PAD
4371A7:
MT KNOB - LEATHER WRAPPED+CR COAT'G
5272A1:
RR AXLE FUNCTION - 2WD L.S.D
5611B3:
3-SPOKE - LEATHER
819BA1:
KEYLESS ENTRY-PANIC
819HA1:
SMART KEY-FR DR
8196A2:
BUTTON START - BUTTON With ILLUMINATED
8197A2:
FOB HOLDER With ILLUMINATED
8198A3:
STEER'G LOCK TYPE - ESCL
8233E1:
CENTER TRIM - ARTIFICIAL LEATHER
8262A2:
LEVER FINISH'G - CR COAT'G
84CAA1:
A/TRAY COVER
84CRA1:
CUP HOLDER COVER
8441A5:
FR - PORTABLE
8445A1:
CIGAR LIGHTER - Without ILLUM.
848BA1:
CTR FACIA PNL
848CA1:
CONSOLE UPR COVER
8511C1:
ELECTRIC CHROMIC MIRROR TYPE
8579A1:
LUGGAGE NET
858RB1:
SUS TYPE - A TYPE
86A1A1:
With WIPER DEICER
8721B1:
RR SPOILER With HMSL - A TYPE
8762C4:
PASS'S SIDE - ELECTRIC HTD-CONV
8763C4:
DRIVER'S SIDE - ELECTRIC HTD-CONV
8811E2:
PURE LEATHER
ACTIVE HEAD RESTRAINT
8827A1:
POWER SEAT
8838A1:
SEAT WARMER(HEATER)
8873A1:
SEAT WARMER
9213A2:
DAYTIME RUNN'G LIGHT - EUROPE TYPE
9221F1:
SPORTY TYPE - MFR
94F3A1:
CRUISE CONTROL
94G4A1:
FOG LAMP (FR)
9511A1:
AUTO LIGHT CONTROL SYSTEM - 1 STAGE
9571A3:
RR PARK'G ASSIST SYSTEM(RPAS)
961DA1:
USB+IPOD
9611P9:
RADIO+CDC+MP3 - PA 760
963EA1:
SPEAKER LOCATION CENTER-FR
963TA1:
SPEAKER - SUB WOOFER
963VB1:
SPEAKER BRAND - PREMIUM
963WA2:
EXTERNAL AMP - JBL AMP
9641A1:
AUTO CRUISE CONTROL - CONVENTIONAL
965AA1:
DISTANCE TO EMPTY(D.T.E)
965BA1:
AVERAGE FUEL CONSUMPTION(AFC)
965CA1:
AVERAGE VEHICLE SPEED(AVS)
965EA1:
INSTANT FUEL CONSUMPTIO
TYPE - SEPARATED TYPE
967AA1:
AUDIO REMO.
967BA1:
ACC REMO.
9721D1:
ELEC TYPE - SOFT TOUCH TYPE
9761A3:
FR COOLER - FULL AUTO A/CON
Hyundai Genesis GENESIS COUPE 2014/03/31 19:43 #59381
  • karolek55
  • karolek55 Avatar
Witam. Moim zdaniem już po zdjęciach widać że z autem jest nie halo.
Hyundai Genesis GENESIS COUPE 2014/03/31 19:48 #59382
  • karolek55
  • karolek55 Avatar
Już lepiej kupić coś takiego, sprawdzić sobie dodatkowo po vinie czy tylko to sie działo co na fotach i fachowo zrobić, przynajmniej wiesz czym jeździsz.
otomoto.pl/hyundai-genesis-coupe-2-0t-sp...acony-C32237998.html
Hyundai Genesis GENESIS COUPE 2014/04/01 10:07 #59394
  • PagerOwski
  • PagerOwski Avatar
Witam, sam się zastanawiam nad nim - dość niski przebieg(możliwe ,że auto stało - bo było uszkodzone) niestety nie znalazłem nigdzie takowych informacji (nawet tutaj), a szkoda. Jeżeli chodzi o samochód jaki podałeś w linku powyżej - również nie jest za specjalny. Po 1 z tego co widzę po uszkodzeniu został już naprawiany(aby wyglądał na lekko uszkodzony)Dziwi mnie fakt, iż poduszki są całe... no cóż kupić odpowiednie auto to droga przez wieczność.
Gdzie można się jeszcze dowiedzieć czegokolwiek na temat uszkodzeń czy też przebiegu?
Hyundai Genesis GENESIS COUPE 2014/04/01 13:21 #59404
w aso i od wlasciciela poprzedniego. Tu sie nawet rocznik nie zgadza z tym samochodem. Cos nie tak
Hyundai Genesis GENESIS COUPE 2014/04/01 15:32 #59442
  • karolek55
  • karolek55 Avatar
Ja swojeg Gena zakupiłem z USA po sprawdzeniu vinu (było lekko pacnięte)ale zostało naprawione solidnie i uszkodzenia były niewielkie. Może zleć komuś sprowadzenie auta z USA - nadal opłaca się i to dość tak. :)
Hyundai Genesis GENESIS COUPE 2014/04/01 18:31 #59454
  • karolek55
  • karolek55 Avatar
allegro.pl/hyundai-genesis-coupe-2-0t-2010-rok-i4114802029.html
Sprawdź sobie tego po vinie bo jest z USA. Troche kolor nie halo, ale jeżeli auto jest tak jak facet pisze od nowego w jego łapkach to bierz nie patrząc na kolor. Wersja wyposażenia jest przyzwoita ale powinien zejść z ceny na 55-53tysie. Autko sprzed liftu wewnętrznego, ale jak dobre to brać i jechać jak to mawiają marne polskie handlarzyny.Pozdr fanów Genesis;)
Hyundai Genesis GENESIS COUPE 2014/04/01 21:25 #59464
  • PagerOwski
  • PagerOwski Avatar
dzięki za informację i pomoc. Pozdrawiam. (Jak coś ustrzelę , dam znać)
Hyundai Genesis GENESIS COUPE 2014/04/02 15:30 #59503
Panowie 1 temat 1 auto. Propozycje na priv prosze podawac sobie
