WT 3:
| TEMPERATE ZONE |
2111A2:
2841G2:
| EMISSION REGULATION - FED. 10 |
2841J1:
| EMISSION REGULATION - CAL. 09 |
2841J2:
| EMISSION REGULATION - CAL. 10 |
2843A6:
| EVAP. GAS CONTROL - LEV-2 |
2844B2:
| EMISSION LABEL - USA TYPE |
2861B3:
2865A2:
| MUFFLER MATERIAL - SUS |
2891C1:
| CATALYTIC CONVERTER - W.C.C+U.C.C TYPE |
3111C4:
| FUEL TANK-CAPACITY - 65 LITER |
3281A1:
| PEDAL TYPE - RUBBER PAD |
| BATTERY SAVER |
3711A9:
3921A2:
4503A2:
| SHIFT LOCK SYSTEM - ELECTRONIC TYPE |
4504A2:
| IGN. KEY INTER LOCK SYS-ELECTRONIC TYPE |
4509A3:
| GATE TYPE H-MATIC |
4911A2:
| PROPELLAR SHAFT - TWO PIECE |
4951D9:
| LH/RH - VL3300I+VL3300I |
529AA2:
| TIRE PRESSURE LABEL - U.S.A |
5291T1:
| AL WHEEL 7.5J*18 : 8.0J*18 - A TYPE |
5293HK:
| 225/45 R18 : 245/45 R18 (ALL SEASON) |
5294B4:
| TIRE SOURCE - BRIDGESTONE |
5297G3:
| STEEL WHEEL & TIRE (4.0T*17 T135/90D17) |
| S/ABSORBER TYPE - GAS |
5511B2:
| RR SUSP TYPE - MULTI LINK-SPORTY |
5631A3:
| STEER'G COLUMN-MANUAL LWR TILT |
5691A2:
| DRIVER SIDE - ADVANCED |
5692A2:
| PASSENGER SIDE - ADVANCED |
5711A2:
| HPS(HYDRAULIC POWER STRG) |
5811A6:
| FR BRAKE - DISC-17 INCH |
5812A9:
| RR BRAKE - DISC-16 INCH |
| ABS (ANTI LOCK BRK SYS) |
5911B4:
| TANDEM BOOSTER - 7+8 INCH |
5971A1:
8112A2:
812AA1:
| T/LID EMERGENCY RELEASE |
8122A2:
8124A1:
| TRUNK LID TRIM - FULL COVER |
813AA1:
| SPEED SENS'G AUTO DR LOCK |
813MA1:
| SECURITY INDICATE |
8131A2:
8132A1:
| TWO TURN UNLOCK'G - DRIVER ONLY |
8135A2:
8152A4:
| KEYLESS ENTRY-B/ALARM |
819BA1:
| KEYLESS ENTRY-PANIC |
8195A2:
| IGNITION ILLUMINATED - LED TYPE |
82A5A1:
| DR FRAME MLDG - BLACK |
8231B2:
| FORMED TYPE - DLX |
8233B1:
| CENTER TRIM - CLOTH(A TYPE) |
| FR DR GLASS - TINTED |
| FINISH'G - BODY COLOR |
834CA2:
| SAFETY WINDOW - FR DR |
834DB2:
| AUTO UP & DOWN - FR DR |
8341A1:
| POWER WINDOW(FR) |
8347A1:
| SW ILLUMINATION(DR) |
84L3A1:
| A/T INDICATOR |
8421E1:
| T/C PILE - CARPET_STD |
846BA1:
846LA3:
846NA1:
| POWER OUTLET |
8462A1:
85ACA1:
| TRUNK LID INR TRIM - WALL PAPER |
85APA1:
| TOOL CASE(OVM TOOL) |
| TICKET HOLDER |
| VANITY MIRROR COVER |
852DA1:
| ILLUMINATED |
852EA1:
| TYPE - EXTENSION |
852GA1:
852KA1:
| ILLUMINATED |
8521A3:
| MATERIAL - CLOTH(STD) |
8522A1:
8523A3:
8531A3:
8561A2:
| RR P/TRAY MATERIAL - WithPAPER |
8571C1:
| LUGGAGE SIDE - WithPAPER |
8572A3:
| RR - WALL PAPER |
8573A2:
| FLOOR - WALL PAPER |
| LUGGAGE NET HOOK |
| MLD'G-WINDSHIELD - BLACK |
863CA1:
| GRADE - GL |
8631A1:
| A' TYPE - BLACK |
| TOWING HOOK |
| TIE DOWN HOOK(LASHING) |
8648A1:
| ANTI-CORROSION TREATMENT |
8649B5:
| ID PLATE - USA |
| RR HEATED With TIMER |
8711A1:
| MLD'G-BACK LITE - BLACK |
8722A3:
| H.M.S.L - RR P/TRAY |
8762C2:
| PASS'S SIDE - ELECTRIC-CONV |
8763C1:
| DRIVER'S SIDE - ELECTRIC-FLAT |
| COLOR - BODY COLOR |
8772B1:
| MLD'G-S/SILL - BODY COLOR |
8811C1:
| CLOTH - CLOTH |
8821A3:
| SLIDING |
| DOUBLE RECLIN'G |
8828A1:
| LUMBAR SUPPORT - MANUAL |
885RA1:
| PODS-B |
8854A3:
8866A1:
888DA1:
| SEAT BELT REMINDER |
| LOAD LIMITER |
888FA1:
| BUCKLE SENSOR |
888NA1:
| BUCKLE SENSOR |
| DRIVER'S SIDE - ELR |
| PASSENGER'S SIDE - ELR |
8885A2:
8888A1:
| BELT TENSION SENSOR |
| LOAD LIMITER |
8912L3:
| FOR 2 PEOPLE - BENCH-FOLD'G |
| HOLDER - UPR ANCHOR |
| LWR ANCHOR |
8981A5:
| SIDE - CLR |
9234A1:
| SIDE MARK - FR |
9235A1:
| SIDE MARK-RR |
9245A1:
| LAMP TYPE - INTEGRATED |
928HA2:
| FR - REFLECTOR |
928WA2:
| BULB TYPE - 2 BULB |
9286A1:
| GLOVE BOX LAMP |
| LUGGAGE LAMP |
94C1A1:
| A/T POSITION INDICATOR |
| DIRECTION INDICATOR |
| OIL PRESSURE |
| BRAKE OIL |
| PARK'G BRAKE |
| DR AJAR - DR AJAR |
| BATTERY CHARGE |
| HIGH BEAM |
| LOW FUEL |
| TRUNK LID(T/GATE) OPEN |
| CHECK ENGINE |
| SEAT BELT |
| A/BAG |
94G0A1:
| WASHER FLUID WARN'G LAMP |
| E.S.P |
94K3A1:
| TPMS (TIRE PRESSURE MONITORG SYS) |
94M0A3:
| SPEEDOMETER TYPE - MPH(KMPH) |
94N0A2:
| TEMPERATURE UNIT - F |
940AA3:
| TRIP ODOMETER - LCD |
| TACHOMETER |
| FUEL |
| WATER TEMP. |
9401C1:
| SPEEDOMETER |
| TYPE - DIGITAL |
9545A1:
9574A2:
| TIRE PRESSURE MONITORG SYS - LOW LINE |
961AA1:
| AUX |
9614B1:
| COMPONENT- 2 DIN |
9615A2:
| FREQUENCY VIBRATION - AM10K/FM200K |
9621E1:
| GLASS ANTENNA - RADIO |
9624L1:
| ANTENNA SDARS |
963GA1:
963KA1:
9661B1:
| DUAL HORN - DISK TYPE |
967KA1:
| PADDLE SHIFTER - LEVER TYPE |
9681A1:
| SEAT BELT |
9684A1:
| KEY OPERATED WARN'G |
| FUNCTION - AIR FILTER |
972DA1:
| O/SIDE TEMPERATURE GAUGE |
| FR WIPER-2 SPEED |
9817A1:
| MIST FUNCTION |
9819A1:
| BLADE TYPE - CONVENTIONAL |
9909A2:
| USA - CALIFORNIA |
4371C2:
| AT KNOB - LEATHER WRAPPED+CR COAT'G |
5416A1:
| STRUT TOWER BAR |
5611B3:
| 3-SPOKE - LEATHER |
5693A3:
| SIDE AIR BAG-FR - FR(THORAX & PELVIS) |
| CURTAIN A/BAG |
8161C2:
| SINGLE TILT'G & SLID'G - POWER-NORMAL |
819HA1:
| SMART KEY-FR DR |
8196A2:
| BUTTON START - BUTTON With ILLUMINATED |
8197A2:
| FOB HOLDER With ILLUMINATED |
8198A3:
| STEER'G LOCK TYPE - ESCL |
8262A2:
84CAA1:
| A/TRAY COVER |
84CRA1:
| CUP HOLDER COVER |
848BA1:
| CTR FACIA PNL |
848CA1:
| CONSOLE UPR COVER |
8511F1:
| ECM+HOME LINK SYSTEM+COMPASS TYPE |
8652B3:
| COLOR - BODY COLOR + BLACK |
| ACTIVE HEAD RESTRAINT |
8827A1:
| POWER SEAT |
94F3A1:
| CRUISE CONTROL |
| IMMOBILIZER |
941AA1:
| TORQUE METER |
941CA3:
| FUEL CONSUMPTION |
9511A1:
| IMMOBILIZER |
9552A1:
| BLUE TOOTH (AUDIO) |
961DA1:
| USB+IPOD |
9611W7:
| AV - DOMESTIC (LOW) |
9625C2:
| ANTENNA DIVERSITY - GLASS+GLASS |
963EA1:
| SPEAKER LOCATION CENTER-FR |
963TA1:
| SPEAKER - SUB WOOFER |
963VB1:
| SPEAKER BRAND - PREMIUM |
963WA2:
| EXTERNAL AMP - JBL AMP |
9641A1:
965AA1:
| DISTANCE TO EMPTY(D.T.E) |
965BA1:
965CA1:
| TYPE - SEPARATED TYPE |
9654A3:
| NAVIGATION SYSTEM(LOW) - NAS |
967AA1:
| AUDIO REMO. |
967BA1:
| ACC REMO. |
967DA1:
| H/FREE REMO |
9721D1:
| ELEC TYPE - SOFT TOUCH TYPE |
9761A3:
