Prosiłbym bardzo o sprawdzenie tego auta. Kolega chciałby kupic i chcialbym dowiedziec sie o przebiegu oraz o bezwypadkowsci. Podaje numer VIN WF0KXXGCBKBU64871 Sprawdź ten VIN na autobaza.pl ▸ Oraz ogłoszenie www.otomoto.pl/oferta/ford-focus-automat...VwBgK-C23WaIKzWZwHpo Prosze o pomoc byłbym bardzo wdzieczny |
Opcje wyposażenia:
Engine Cover - Under Hood Engine Cover - Under Hood Passengers Air Bag With Passenger Air Bag Front Fog Lamp Type With Front Fog Lamps Maplight Front And Rear Lamp LED Suspension Types With Standard Suspension Drivers Seat Adjustment Type With Driver 4 Way Mnl.Seat Adjuster Door Mirror Finish With Body Coloured Exterior Mirror Door Locking Systems With Central Locking System Headlamp Levelling Type With Manual Headlamp Levelling Speedometer Types With KMH Speedometer Marketing Levels Marketing Level 1 Passenger Seat Adjustment Type With Pass 2 Way Manual Seat Adjust Door Remote Control Unit With Door Entry Remote Control Unit Overhead Console Mini Overhead Cnsl W/Sunglass Bin Fuel Tank Lock Non Locking Capless Fuel Fill Front Headrests With Front 2 Way Headrest Fresh Air Heater With Recirculating Heater Wheel Lug Nuts Non Locking Lug Nuts Side Air Bag - Passenger Side With Side Air Bag - Passenger Side Voice Activated Modules Voice Activated Module - French Rear Headrest Type With Integrated Rear Headrest 17 Inch Tyres 215/50 17 W Rated BSW Tyre High Mounted Stop Lamp With High Mounted Stop Lamp Shutters - Radiator With Kysor Radiator Shutter Rear Passenger Door Rear Passenger Door Batteries Standard Duty Battery Headlamps - Design With Halogen Headlamp Rear Bumper Rear Bumper Body Coloured Plastic Door Frame Moulding Type With Bright Door Frame Moulding Front Window Operation Power Front Windows One Touch Up/Do Tripminder With Trip Computer Front Floor Mat Style With Velour Front Floor Mats Heated Windscreen With Heated Windscreen Brake Calipers And Pads Standard Duty Fr/Rr Calp And Pads Exterior Mirror Dual Dual Pwr/Heat/Fold/Pud Lamp/Signal Rear Floor Mats Style With Velour Rear Floor Mats Headrestraint - Rear Center With Rear Center Head Restraint Rear Shock Absorber Type With Standard Rear Shock Absorbers Door Handle - Exterior Body Coloured Exterior Door Handle Load Floor Covering With Load Floor Carpet Air Curtain Restraint(RH/LH) Air Curtain Restrnt LH Tailgate Release With Remote Controlled Tailgate Release Front Seat Belt Mounting With Manual Adjust Frt.S.Belt Mount Steering Column Types With Manual Tilt/Slide Stg Column Rear Seat Belts Retractable Rear Seat Belt-3Point Air Curtains (Use CP1 Family) Air Curtain Restrnt RH City Safety Low Speed Safety System Rear Tyre Tread Pattern With Standard Tyre Tread - Rear Foot Pedal Design Standard Foot Pedal Pad Design Front Tyre Tread Pattern With Standard Tyre Tread - Front Load Compartment Lamp With Load Compartment Lamp Power Point Rear With Power Point Plug - Rear Isofix Hard Point Attachment With Isofix Hard Point Attachment Transmission Gear Sets 3.58/1.95/1.19/0.84/0.94/0.79 Speed Sign Recognition Speed Sign Recognition Instrumentation Type Conventional Instruments - Level 3 Tail Lamps Tail lamps - LED Rear Adjustable Foot Pedals With Fixed Foot Pedals Seatbelt Anchorage 3 Part Seat Belt- European Regultn Smokers Package With Smokers Package Centre Console Console - With Closed Bin Side Air Bag - Drivers Side With Side Air Bag - Drivers Side Drivers Air Bag With Driver Air Bag LH Arm Rest With LH Front Door Armrest Spare Wheel Type Spare Wheel - Mini Steel Fog Lamp Bezel With Chrome Fog Lamp Bezel Single Note Electric Horn Dual Note Electric Horn Exhaust Systems Strt Sngl Vsbl Pipe One Sd Sngl Muf Steering Wheel Radio Controls With Steering Wheel Radio Controls Exterior Tailgate Handle Body Coloured Tailgate Handle Corporate Badge Ford Corporate Badge Drv St Back Mtd Map Pocket With Driver Seat Back Map Pocket Front Spring Load Class Front Spring Load Class-R Rear Window Operation Power Rear Window One Shot Up/Down Outer Rocker Panel Moulding Colour Rocker Panel Moulding -Cladding C/K Exterior Paint Pack Exterior Paint - Solid Lumbar Seat Support Driver Seat With Drivers Manual Lumbar Support Starter Motor Type Standard Electric Starter Motor Rear Brake Type With Rear Disc Brakes In Car Entertainment ICE- Mid Audio (1C) W/Connectivity Pass Seat Back Mtd Map Pocket Passenger Seat Back Map Pocket Lane Keeping Aid Lane Keeping Aid Blind Spot Information System BIS W/Radar-BLIS/CAN LED Steering Types With Electric Power Steering Plant Build Requirements Saarlouis Plant Built Front Heated Washer Jets With Heated Washer Jet Blue Tooth Interface Connect BT/VC Phone Interface + USB Connect RH Arm Rest With RH Front Door Armrest Header Mounted Map Reading Lamps Fr Individual and Rr Map Lights Engine Immobilizers With Engine Immobilizr - Securilock Gearshift Knob With Leather Gear Shift Knob Navigation Data Navigation Data - Western Europe General Stowage Box With General Stowage Box Radio Speakers With 6 Speakers Parking Brake - Function Type Mechanical Hand Operated Park Brake Rear Seat Centre Armrest Rear Centre Armrest With Stowage Rear Spring Load Class Rear Spring Load Class-Q Fuel Filler Door Lock Capless Fuel Filler Without Lock Auto Headlamps With Auto Headlamps Cold Start Type Cold Start -29 Deg C Temperature Zones For Normal Temperature Zones Seat Belt Warning Type With Drvr/Passngr Seat Belt Minder Rear View Mirror Type With Electrochromic R/View Mirror Marketing Flex Prep Pack Leather Pack Syracuse Rear Towing Hooks With Rear Towing Hooks Glove Box Lamp With Glove Box Illumination Windscreen Wash/Wipe With Automatic Windscreen Wiper Module Configuration Outside Air Temperature Present Sunvisors - Driver With Illuminated Sunvisor - Drivers Sunvisors - Passenger With Illuminated Sunvisor-Passenger Front Towing Hooks With Front Towing Hook Child Proof Locks With Child Proof Safety Lock Speed Control Speed Control And ASLD Tether Anchorage Style 1 Tether Anchorage Restraint Interior Cab Assist Handle - Driver Rear Coat Hook Driver Impairment Monitor Driver Impairment Monitor Global Closing With Auto Closing Windows Drivers Recliner Seat With Driver Seat Recliner - Rotary Rear Spoiler Type With Large Single Wing Rear Spoiler Headlamp Bezels With Black Headlamp Bezels Instrument Cluster - Rheostat With Instrument Cluster - Rheostat Tinted Glass With Privacy Glass Fuel Capability Type With Diesel Fuel Capability Rear Window Wash/Wipe With Int. Rear Window Wiper/Washer Ignition Key Type Ignition Key Combination Pack 1 Interior Door Handle Type With Aluminum Interior Door Handles Grille - Lower Lower Grille - Hgh Gls W/Chrm Smile Hill Launch Assist With Hill Launch Assist Interior Feature Colour Int Feat Colour - Charcoal Black Padded Dash With Padded Dash Load Compartment Cover With Load Area Cover Interior Environment Colour Int Environment Clr-Charcoal Black Rear Fog Lamps With Single Rear Fog Lamp Accessory USB Unit Accessory Media Hub 1XUSB Headlamp Control With Auto High Lamp Headlamp Integrated Control Panel ICP Nav Rear Side Air Bag Anti-Lock Brakes Brakes-HLA/ESP/TC/ABS Footwell Lights With Footwell Lights Wheel Size/Style - 17 7J X 17 Style 5 Alloy Wheel Steering Wheel Type 4 Spoke Leather Steering Wheel Auxiliary Heater With Supplemental Air Heater Air Purifier Pollen/Carbon Filter Folding Rear Seat Type With 60:40 Split - Folding Rr Seat Grille - Upper Grille - Upper Blk Msh/Chrome Surnd Message Centre With Message Centre Passenger Recliner Seat With Passenger Seat Recliner-Rotary Interior Light Group Interior Lighting-Ambient LED Headlinings Deluxe Headliner Liftgate With Manual Liftgate Rear Seat Cushion Type With Two Piece Rear Seat Cushion ICE Feature Pack With ICE Feature Pack 11 Front Seat Type With High Back Front Seats Tyre Spare Limited Service Mini Spare Tyre Front Door Sill Protection Front Door Scuff Plates - Ford Oval Keyless Entry System Keyless Entry/Start - Passive Tailgate Badges LESS TAILGATE BADGES Front Bumper Front Bumper - Painted Body Colour Multi Function Display MFD Nav Low TFT Screen |
zanim kupi niech zapozna się z kosztami i żywotnością automatów forda
Powershift 6DCT450 prawy przedni błotnik i zderzak przedni jakoś mi się rzucają w oczy Szczegóły Oferta od Firmy Kategoria Osobowe Marka pojazdu Ford Model pojazdu Focus Wersja Mk3 (2010-) Generacja Mk3 (2010-) Rok produkcji 2011 Przebieg 138 000 km Pojemność skokowa 1 997 cm3 Rodzaj paliwa Diesel Moc 140 KM Skrzynia biegów Automatyczna Napęd Na przednie koła Typ Kompakt Liczba drzwi 5 Liczba miejsc 5 Kolor Biały Akryl (niemetalizowany) Tak VAT marża Tak Kraj pochodzenia Francja Pierwsza rejestracja 30/11/2011 Bezwypadkowy Tak Serwisowany w ASO Tak Stan Używane VIN wf0kxxgcbkbu65672 |
Masz racje on był tam przerysowany i naprawiany.
A pisze cos o przebiegu serwisie wypadkowosci ? |
