TEMAT: Ocena/sprawdzenie C2 1.4hdi 2009
Ocena/sprawdzenie C2 1.4hdi 2009 2014/06/20 16:06 #63277
  • bartoszMC
  • bartoszMC Avatar
Proszę o sprawdzenie i rozkodowanie vinu citroena c2 z 2009 roku.
Link do ogłoszenia: otomoto.pl/citroen-c2-68km-117000km-klima-1-4hdi-C32763211.html
Vin: VF7JM8HZC9A042555 Sprawdź ten VIN na autobaza.pl ▸
pozdrawiam
Ocena/sprawdzenie C2 1.4hdi 2009 2014/06/21 23:39 #63324
VF7JM8HZC9A042555
VF7JM8HZC9A042555
France
Citroen
C2
3-door Sedan
Skrzynia biegów:
manual, 5-speed (SensoDrive)
Diesel Fuel
Vehicle family:
C2
AS RPO No:
11805 CA 2 0587
Warranty Start Date:
17/08/2009
Engine serial number:
10 FDBE 2436723
Gearbox serial number:
20 CQ63 1179718
OPB:
7000
BER:
e2*2001/116*0316*05
PRODUCT TYPE:
CAR
CITROEN
VEHICLE FAMILY:
C2
SILHOUETTE:
3 DOOR SALOON
TRIM LEVEL:
LOW / HIGH
DV4TD TURBO DIESEL
BVM5
PAINT TYPE:
NON-METALLIC PAINT
BODY COLOUR:
KKN - PAINT ADEN RED
WARP AND WEFT TRIO + OMNI "2S"
UPHOLSTERY COLOUR:
"FH"
BVM MA5 / O
EV/DV
OTHER BADGE, " MISC. ":
WITHOUT FULLER BADGE
SPEEDOMETER DRIVE:
CT 21 X NO
Turbodiesel DV4TD
Fuel:
DIESEL FUEL
Cover for luggage:
MAGAZINE SHELF
Protecting the front seat:
CABIN WITHOUT PROTECTIVE PANEL
DV4TD TURBO DIESEL
DIESEL FILTER WATER DETECTOR:
WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL):
CRANKCASE ALUMINIUM
DIESEL FUEL
ANTI DEPOLLUTION L5 (ENGINE)
SPEED SENSOR SIGNAL:
MULTIFUNCTIONAL ACTIVE SENSOR
EV/DV
CATALYTIC CONVERTER:
2-COMPONENT CATALYSER 50 PPM LOWER PLATE
COOLING MOTOR:
RADIATEUR EP:27 - 16 DM2 ALU BRASE SS MEC
W/O HEATER CASING GAS CIRCUIT
"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION):
"EGR" EXHAUST GAS RECYCLING
L5 VEHICLE TECHNICAL DEPOLLUTION
WITHOUT PARTICLE FILTER
1 AERO 2-SPEED 90W FAN
FUEL VAPOUR RETRIEVAL:
WITHOUT PETROL VAPOUR RECUPERATION
SIEMENS ASSEMBLY
HYBRID DRIVE TRAIN:
WITHOUT ALTERNATOR-STARTER
TANK FILTER:
CITHOUT RESERVOIR FILTER
STOP AND START:
WITHOUT STOP AND START
BVM5
BVM MA5 / O
REAR AXLE HYPOID GEARSET 17 X 61
SPEEDOMETER DRIVE:
CT 21 X NO
14 INCH STEEL WHEEL
DIFFERENTIAL (GEARBOX):
DIFFERENTIAL 77
RIM/TYRE SIZE:
14 INCH TYRE FITMENT
175X65X14 T TYRES
WHEELS FITTED:
5,5" RIM ROAD WHEELS
STEEL WHEELS
MA
ABS:
WITH ABS BRAKES
REAR ANTI-ROLL BAR:
REAR ANTI-ROLL BAR DIAM 23.5
FRONT ANTI-ROLL BAR DIAM 19
BRAKE TYPE:
NON-VENTILATED FRONT DISCS/REAR DRUMS
NORMAL SUSPENSION
WITHOUT ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT:
ABS TEVES MK70
ELECTRIC STEERING:
60 AMPERES ELECTRIC STEERING
PEDAL BRACKET (TYPE):
PEDAL STANDARD
TOWBAR:
WITHOUT TOWBAR
AERIAL:
SHORT ROOF AERIAL
OPENING ROOF (APPEARANCE):
WITHOUT SUN ROOF
REAR SPOILER:
ASSEMBLY WITHOUT REAR SPOILER
BODY COLOUR LATERAL PROTECTORS
14 INCH 14-SPOKE CONDOR STYLE
UNDERBODY SHIELD:
PLASTIC PROTECTIO + FOAM UNDER ENGINE
W/O ENGINE UNDERSHELDING
EXT MIRROR MANUAL-FOLD BACK
EXHAUST TAILPIPE TRIM:
W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING:
BONNET SOUNDPROOFING
INTERMITTENT WINDSCREEN WIPER+ADJUST
W/O HEADLAMP WIPER
WITHOUT FRONT BUMPER PLUG
REAR TAILGATE GLASS:
FIXED TAILGATE WINDOW
OUTSIDE TEMPERATURE SENSOR:
WITH EXTERIOR TEMPERATURE SENSOR
BUMPER:
BODY COLOUR / BLACK APPEARANCE FR+RR BUMPER
NO FRONT FOG LIGHTS
DRIVER’S DOOR MIRROR ELECTRIC CONTROL
PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
STEEL WHEEL + STANDARD TYRE
UNCOLOURED DOOR HANDLES + DOOR MIRRORS
SPARE WHEEL MOUNTING:
STANDARD SPARE-WHEEL CARRIER
FIXED ROOF
NON ATHERM WINDSCREEN+TOUGH SIDE AND RR WINDOWS
WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT:
WITHOUT REAR HEADREST
FRONT HEAD RESTRAINT:
FRONT HEADREST ADJUSTABLE
RR BENCH MONOBLOCK CUSHION SEPA FOLDING BACK
LUGGAGE COVER:
SHELF
REAR INERTIA-REEL SAFETY BELT
FRONT SEATBELT:
PYROTECHNIC SEAT BELT WITH ALARM
TEMPERATE COUNTRIES
GRADUATION KMS/H
GRAB HANDLES:
HANDLE FR PASS + HOOK
RADIO EQUIPMENT:
FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
LEFT HAND DRIVE
REMOTE CONTROL:
REMOTE CONTROL ASSEMBLY
STANDARD FASCIA PANEL + SOLID COLOUR CONTROL PANEL
MISC. INT. LAMPS:
W/O MAP READING LAMP
DIGITAL INSTRUMENT PANEL NEUTRAL FRONT PANEL
4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
REMOTE RADIO CONTROL
POLLEN FILTER:
WITH POLLEN FILTER
WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL:
MEMORY CTRL DRIVERS FRONT SEAT
DRIVER SEAT ADJUSTMENT:
RECLINING DRIVER’S SEAT BACK
FRONT SEAT ARMREST:
ASSEMBLY WITHOUT FRONT ELBOW REST
WITHOUT COMPACT DISC
WITHOUT NAVIGATION SYSTEM
DRIVER’S WINDOW LIFT:
SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT:
STD ELEC CONTROL FRONT PASSENGER ELECTRIC WINDOW
DISPAY (RADIO+CLOCK+AND OR T°, CD) WITHOUT MEMORY
CLOCK:
NUMERIC CLOCK
COURTESY MIRROR:
DRIV OCCULT+PASS OCCULT W/O LIGHT
OIL GAUGE:
STD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT:
WITHOUT REAR HEAD-REST
NON HEATED SEAT
WITHOUT FRONT SIDE AIRBAG
ON-BOARD COMPUTER:
COMPUTER
NON HEATED DOOR MIRROR
MANUAL AIRBAG DEACTIVATION
INT DOOR HANDLE GREY LION
FRONT SEAT GUARD:
WITHOUT CAB PROTECTION PANEL
STORAGE (DRIVING POSITION):
LOWER STORAGE COMPARTMENT WITHOUT LOCK
"RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM
SINGLE AIR CONDITIONING
WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL:
PARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR:
DAY -NIGHT INNER REAR MIRROR
STORAGE (OTHERS):
W/O OTHER SETTING BOXES
DRIVER AIRBAG:
DRIVERS AIR BAG
LOAD SPACE STORAGE:
W/O BOOT TIDY
EXTERIOR TEMPERATURE (SCALE):
EXT TEMP INDICATOR CELSIUS
OBSTACLE DETECTION SYSTEM:
WITHOUT OBSTACLE DETECTOR
G/LEVER KNOB LEATHER CHROME INSERT
SIMPLE CENTRAL LOCKING
RUBBER STEERING WHEEL
ALTERNATOR 150 AMP
BATTERY L2 400
STARTER MOTOR CL 4
WITHOUT PARTICULAR LIGHT
CEN. LOCKING REM CONTROL FREQUENCY:
LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
MULTIPLEXING:
MULTIPLEXING ASSEMBLY CAN CAN
FURIO 3
NORMAL ATMOSPHERE
RADIO HEADPHONE SOCKET:
WITH ACCESSORIES SOCKET
TRAFFIC SIDE:
DRIVING ON THE RIGHT-HAND SIDE
EMERGENCY EQUIPMENT:
W/O HELP EQUIPMENT
SPEED MONITORING:
PROGRAMMED OVERSPEED WARNING
EMERGENCY WARNING TRIANGLE:
WITHOUT WARNING TRIANGLE
