| Turbodiesel DV4TD |
Fuel:
| DIESEL FUEL |
| Emission standard L5 (ENGINE) |
Standard for emissions of exhaust gases in the atmosphere (as approved):
| Emission standard L5 (HOMOLOGATION) |
Technical means to protect the environment:
| CAR with technical cleaning L5 |
Stop and Start System:
| NO SYSTEM "STOP AND START" |
ABS:
| With ABS brakes |
Suspension:
| Conventional suspension |
Towing system:
| FREE Hook |
The secondary screen (under the engine):
| WITHOUT PROTECTION CRANKCASE |
Rear seat:
| WHOLE PAD ZADN.SID. With RAZD.SPIN. |
Cover for luggage:
| MAGAZINE SHELF |
Window Lifter driver's side door:
| POSLED.EL.STEKLOPOD.OKNA DRIVER. |
Airbag on the passenger side:
| Passenger Airbag |
Onboard computer:
| TRIP COMPUTER |
Protecting the front seat:
| CABIN WITHOUT PROTECTIVE PANEL |
Airbag driver side:
| Driver Airbag |
Audio equipment:
| NO AUDIO PACKAGE |
| Dv4td turbo diesel |
| Diesel fuel |
| Anti depollution l5 (engine) |
SPEED SENSOR SIGNAL:
| Multifunctional active sensor |
| Ev/dv |
CATALYTIC CONVERTER:
| 2-component catalyser 50 ppm lower plate |
| Without oil-water distr chamb |
COOLING MOTOR:
| Radiateur ep:27 - 16 dm2 alu brase ss mec |
| W/o heater casing gas circuit |
| "eobd" auto-diagnostic without accelerometer |
DEVICE (ANTIPOLLUTION):
| "egr" exhaust gas recycling |
| L5 vehicle technical depollution |
| Without particle filter |
| 1 aero 2-speed 90w fan |
FUEL VAPOUR RETRIEVAL:
| Without petrol vapour recuperation |
| Mounting bosch |
TANK FILTER:
| Cithout reservoir filter |
STOP AND START:
| Without stop and start |
| Bvm5 |
| Bvm ma5 / o |
| Rear axle hypoid gearset 17 x 61 |
SPEEDOMETER DRIVE:
| Ct 21 x no |
| 14 inch steel wheel |
GEARBOX TYPE (TYPE APPROVAL):
| Gearbox ma/5 0 |
DIFFERENTIAL (GEARBOX):
| Differential 77 |
RIM/TYRE SIZE:
| 14 inch tyre fitment |
| 175x65x14 t tyres |
WHEELS FITTED:
| 5,5" rim road wheels |
| Steel wheels |
| Ma |
REAR ANTI-ROLL BAR:
| Rear anti-roll bar diam 23.5 |
| Front anti-roll bar diam 19 |
BRAKE TYPE:
| Non-ventilated front discs/rear drums |
STEERING TRAVEL:
| Steering mechanism travel 72 |
| Normal suspension |
| Without electronic stability program |
BRAKE ASSOCIATED VARIANT:
| Abs teves mk70 |
ELECTRIC STEERING:
| 60 amperes electric steering |
PEDAL BRACKET (TYPE):
| Pedal standard |
TOWBAR:
| Without towbar |
AERIAL:
| Short roof aerial |
OPENING ROOF (APPEARANCE):
| With glass sunroof |
| Body colour lateral protectors |
SIDE MOULDINGS (DIMENSION):
| Without body sill protectors |
| 14 inch 14-spoke condor style |
UNDERBODY SHIELD:
| Plastic protectio + foam under engine |
| W/o engine undershelding |
| Ext mirror manual-fold back |
EXHAUST TAILPIPE TRIM:
| W/o exhaust outlet embellisher |
| Front wiper blade w/o rain sensor |
| W/o headlamp wiper |
| Without front bumper plug |
REAR TAILGATE GLASS:
| Fixed tailgate window |
OUTSIDE TEMPERATURE SENSOR:
| With exterior temperature sensor |
BUMPER:
| Body colour front/rear bumper |
LUGGAGE RACK:
| Without roof bars |
| Front fog lights |
| Driv ext rrvw mirror non heat elec contr |
| Pass ext rrview mirror non heated elect cntrl |
| Steel wheel + standard tyre |
| Neutral ext handle+flap trim+ext rr view mirror |
| Sunroof sequential assisted control + anti pinch |
BUMPER TRIM:
| Body colour bumper strip |
| Non athermal windscreen |
EXTERIOR STYLING PACK:
| Body colour exterior look pack |
| Warp and weft anjou + misteco "2p" |
| Without theft protection alarm |
REAR HEAD RESTRAINT:
| Rear headrest adjustable |
FRONT HEAD RESTRAINT:
| Jointed front headrest |
| Rear bench seat single cushion separate seat backs |
LUGGAGE COVER:
| Shelf |
| Rear inertia-reel safety belt |
FRONT SEATBELT:
| Pyrotechnic seat belt with alarm |
| Temperate countries |
CHILD LOCK:
| Manual rear child lock |
| Graduation kms/h |
GRAB HANDLES:
| Pass fr handle + rear + hook |
RADIO EQUIPMENT:
| Feed aerial receiv frt speaker twt rear speaker |
| Left hand drive |
REMOTE CONTROL:
| Remote control assembly |
AIR EXTRACTOR:
| Improved air extractor |
| Dashboard standard + facade grey lion |
MISC. INT. LAMPS:
| Map reading lamp |
WORK TABLE:
| Without work table |
LOAD SPACE TRIM:
| Carpet boot mat+carpet sides |
UNDERSEAT STORAGE:
| 1 under seat storage drawer |
| Digital instrument panel neutral front panel |
| 4 fr speakers (2 tw + 2 fr) + 2 rr speakers |
| Remote radio control |
POLLEN FILTER:
| With pollen filter |
PASSENGER COMPARTMENT SOUNDPROOFING:
| 5kg bulkhead soundproofing |
| Without front passenger seat height adjustment |
DRIVER SEAT ADJUSTMENT:
| Reclining driver’s seat back |
FRONT SEAT ARMREST:
| Driver ant passenger front armrest |
| Without compact disc |
| Without navigation system |
| Man ctrl rear window lifter |
DRIVER’S WINDOW LIFT:
| Sequential driver’s electric window |
PASSENGER’S WINDOW LIFT:
| Std elec control front passenger electric window |
| Dispay (radio+clock+and or t��, cd) without memory |
CLOCK:
| Numeric clock |
COURTESY MIRROR:
| Driv occult+pass occult w/o light |
OIL GAUGE:
| Std oil level indicator |
FITTING REAR HEAD RESTRAINT:
| Mount 3 rear head-rest |
| Non heated seat |
| Single front side airbag |
PASSENGER AIRBAG:
| Passenger airbag |
ON-BOARD COMPUTER:
| Computer |
EQUIPMENT PACK:
| Without driving school equipment pack |
| Non heated door mirror |
| Manual airbag deactivation |
| Int door handle grey lion |
FRONT SEAT GUARD:
| Without cab protection panel |
STORAGE (DRIVING POSITION):
| Lower storage compartment without lock |
| "rd4/mp3" rds compact disc audio system |
| Single air conditioning |
| Regulator or speed limit |
DRIVER’S SEAT HEIGHT CONTROL:
| Parallel drv height adj |
STORAGE (OTHERS):
| Solid seat back storage pocket |
DRIVER AIRBAG:
| Drivers air bag |
LOAD SPACE STORAGE:
| W/o boot tidy |
EXTERIOR TEMPERATURE (SCALE):
| Ext temp indicator celsius |
OBSTACLE DETECTION SYSTEM:
| Without obstacle detector |
| Transluscent gear lever knob |
| Simple central locking |
| Rubber steering wheel |
| Without interior child monitoring mirror |
| Alternator 150 amp |
| Battery l2 400 |
| Starter motor cl 4 |
| Without particular light |
CEN. LOCKING REM CONTROL FREQUENCY:
| Locking remote control frequency 433.92 mhz heterodyne |
MULTIPLEXING:
| Multiplexing assembly can can |
| Normal atmosphere |
RADIO HEADPHONE SOCKET:
| Without accessories socket |
TRAFFIC SIDE:
| Driving on the right-hand side |
SIDE IMPACTS:
| Door without reinforcement |
SET OF KEYS:
| 1 hf plip key + 1 single main key |
EMERGENCY EQUIPMENT:
| W/o help equipment |
SURFACE CONDITIONS:
| Good terrain |
SPEED MONITORING:
| Without speed check |
EMERGENCY WARNING TRIANGLE:
| Without warning triangle |
