TEMAT: C4 2.0 VTS 177KM VF7LARFKC74161795 Warszawa
C4 2.0 VTS 177KM VF7LARFKC74161795 Warszawa 2013/12/17 23:27 #53899
  • nelro
  • nelro Avatar
Witam, proszę o informacje o aucie: C4 VTS 2.0 benzyna nr VIN: VF7LARFKC74161795 Sprawdź ten VIN na autobaza.pl ▸. przymierzam się do zakupu tego auta...
tablica.pl/oferta/citron-c4-vts-lpg-2x-o...05-CID5-ID4peu1.html
C4 2.0 VTS 177KM VF7LARFKC74161795 Warszawa 2013/12/18 07:02 #53913
Niezla wersja :)
bez-wypadkowe.net/showthread.php/11378-C...005-Warszawa?p=80878
VF7LARFKC74161795
VF7LARFKC74161795
France
Citroen
C4
3-door Sedan
Skrzynia biegów:
manual, 5-speed (SensoDrive)
Unleaded Gasoline
Vehicle family:
C4
AS RPO No:
10285 88 1 0320
Warranty Start Date:
27/01/2005
OPB:
I3k4
BER:
E2*2001/116*0302*00
PRODUCT TYPE:
Car
Citroen
VEHICLE FAMILY:
C4
SILHOUETTE:
3 door saloon
TRIM LEVEL:
Exclusive vts
Ew10j4s injection
Bvm5
PAINT TYPE:
Metallic paintwork
BODY COLOUR:
Ezw - paint iron grey
Leather ’claudia" entire q3
UPHOLSTERY COLOUR:
"fj"
Bvm be4 t
Ew/dw
OTHER BADGE, " MISC. ":
Vts
INJECTION EW10J4S
Fuel:
UNLEADED GASOLINE
CLEAN ENGINE. IFL5 (NAL.LGOT)
A dynamic system of sustainability:
Electronic Stability Program
Beeps:
SOUND SIGNALS, Melodic
Function outside mirrors:
OUTDOOR. MIRROR with electric. FOLD NO MEMORY
Windscreen wiper:
SCHET.STEKLOOCH.LOB.ST. With DAT.DOZHDYA
Cleaner headlight:
WIPER / WASHER HEADLAMPS
Trunk grille:
WITHOUT BAGAZH.RELSOV ON THE ROOF
Front fog lamp:
FRONT FOG LIGHTS
Luke:
FIXED ROOF
Landing and the engine is started without a key:
Without systems. ACCESS AND START MOTOR. "Hands free"
Rear seat:
FOLDING SEPARATE CUSHION AND BACK SEATS
Tachometer:
DIGITAL TACHOMETER
Additional heating system:
WITHOUT HEATER
Curtains (curtains, side curtains, sunroof):
WITHOUT sunshields
CD:
SETUP. COMPACT DISCS
Lamp lights:
DISCHARGE LAMP
Rear door window lift:
WITHOUT REAR Pwr
Front side airbag:
BOK.POD.BEZOP. THORAX + ZANAV.BEZOP.
Airbag on the passenger side:
Passenger Airbag
Exterior rear-view mirror (heated):
NARUZH.ZERKALO ZADN.VIDA HEATED
System deactivation of airbags:
HAND-OFF AIRBAGS
Protecting the front seat:
CABIN WITHOUT PROTECTIVE PANEL
The air conditioning system:
AUTO AIR CONDITIONING
Cruise Control:
REGULATORS and speed limiter
Adjusting the height of the driver's seat:
PARALLEL Regulus. HEIGHT SIDEN.VODIT.
The inner rear view mirror:
INT. REAR VIEW MIRROR DAY / NIGHT
Airbag driver side:
Driver Airbag
Loading platform:
With cord + Removable Box in the trunk
Interior Protection:
WITHOUT INTERNAL SECURITY
Obstacle detection system:
DETERMINANTS OBSTACLES, FRONT, REAR RADAR
Equalizer amplifier:
An amp EQ
Ew10j4s injection
FUEL SUPPLY:
Injection
DIESEL FILTER WATER DETECTOR:
Without diesel filter water detector
CYLINDER BLOCK (MATERIAL):
Crankcase aluminium
Lead free petrol
Ifl5 engine depollution (tax incentive)
Ew/dw
CAPACITY:
2000 cm3
CATALYTIC CONVERTER:
3-component rhodium+platinum filter catalyser
Mntg water/oil exchanger on engine
COOLING MOTOR:
Radiator th : 27 - 21 dm2 brazed aluminium
W/o heater casing gas circuit
"eobd" auto-diagnostic without accelerometer
Ifl5 vehicle technical depoll (tax incentive)
Without particle filter
2 fans , 2 rates , improved 130waero
FUEL VAPOUR RETRIEVAL:
Controlled petrol vapour recuperation
Mounting magneti marelli
TANK FILTER:
Reservoir filter interior
Bvm5
Bvm be4 t
Cp 17 x 73
17 inch resolfen wheel
CLUTCH:
Hydraulic clutch
GEARBOX TYPE (TYPE APPROVAL):
Gearbox be4/5 t type
DIFFERENTIAL (GEARBOX):
Differential 84
205x50x17 w tyres
WHEELS FITTED:
6,5" rim road wheels
Alloy wheel assembly 2
Tyre deflection indicator
Gearbox be4r
REAR ANTI-ROLL BAR:
Rear anti roll bar diam 27
STEERING COLUMN:
Manually adjusted steering column
Front anti-roll bar diam 22
POWER STEERING FLUID COOLING SYSTEM:
Without power steering oil cooling
Normal suspension
Electronic stability program
BRAKE ASSOCIATED VARIANT:
Esp bosch 8 0
STEERING (OPERATION):
Assisted electrohydraulic steering
PEDAL BRACKET (TYPE):
Pedal aluminium
HORNS:
Horns-harmony
AERIAL:
Short roof aerial
REAR SPOILER:
Assembly with double tailgate central rr spoiler
DECORATION (PAINTED):
Gloss black decor
Body colour lateral protectors
SIDE MOULDINGS (DIMENSION):
Plastic + chrome side protectors
Trompette style
REVERSING LAMPS:
With 2 reversing lamps
SILL ILLUMINATION LAMP:
Sill illumination
W/o engine undershelding
DRAUGHT EXCLUSION:
Bonnet without seal
Electric folding ext rear view mirror no memory
EXHAUST TAILPIPE TRIM:
With exhaust outlet embellisher
ENGINE BAY SOUNDPROOFING:
Bonnet soundproofing
Front wiper blade with rain sensor
REAR SCREEN WIPER:
Rear screen wiper
Headlamp washwipe
Without front bumper plug
ROOF GLASS:
Without roof window
REAR TAILGATE GLASS:
Fixed tailgate window
BUMPER:
Spc grl body col sport fr bumper body col std rr
MUDFLAP:
Without rear mudguard
NUMBER PLATE:
Without licence plate
LUGGAGE RACK:
Without roof bars
Front fog lights
Reduced steel wheel + non std tyre
Body colour ext handle+rr ctrl+pillar+ mirror
Convex exterior mirror glass
Fixed roof
BUMPER TRIM:
Body colour bumper strip
GLASS (APPEARANCE):
Tinted + over-tinted rear
Heated & reflec w/screen + side & rr toughened
No acces and handsfree starting
Without theft protection alarm
CIGAR LIGHTER:
Front cigar-lighter
REAR HEAD RESTRAINT:
Rear headrest adjustable
FRONT HEAD RESTRAINT:
Jointed front headrest
Sepa folding cushion + sepa folding seat back
REAR SEAT ARMREST:
With rear armrest
Rear 3-point 3 inertia reel seat belt
FRONT SEATBELT:
Pyrotechnic seat belt with alarm
Cold countries
CHILD LOCK:
Without child lock
Graduation kms/h
TACHOMETER:
Digital rev counter
Left hand drive
ADDITIONAL HEATING:
Without additionnal heating
Fascia met kurtz low ctrl panel+pen holder painted
MISC. INT. LAMPS:
Map reading lamp
Digital instrument panel lion grey front panel
DOOR TRIM:
Satin chrome door trim decoration
4 fr speakers (2 tw + 2 fr) + 2 rr speakers
Remote radio control
Without sun visor screen
Without front passenger seat height adjustment
DRIVER SEAT CONTROL:
Drivers frt seat manual cntrol
FRONT PASSENGER SEAT CONTROL:
Passenger frt seat manual cntr
DRIVER SEAT ADJUSTMENT:
Driver’s lumbar support
Without passenger’s side and lumbar supports
DRIVER’S SEAT FOLDING:
With fold driv front seating
FRONT PASSENGER SEAT FOLDING:
With fold pass front seating
FRONT SEAT ARMREST:
Central armrest
Without compact disc
STOWAGE BIN:
With setting box
Without navigation system
HEADLAMP BULBS:
Discharge bulb
Without rear glass lift
TRAFFIC INFORMATION READER:
Without lateral trajectory monitoring
Display (radio+clock,t��,cd)
COURTESY MIRROR:
Driver’s + passenger’s concealable with light
OIL GAUGE:
Std oil level indicator
FITTING REAR HEAD RESTRAINT:
Mount 3 rear head-rest
Heated seat
Thorax side + curtain airbag
PASSENGER AIRBAG:
Passenger airbag
ELECTRIC WINDOW (OPERATION):
Driver + passenger electric window auto stop
EQUIPMENT PACK:
Without driving school equipment pack
Heated door mirror
Manual airbag deactivation
Soft mistral appearance interior door control
REAR LOAD FLOOR:
Without rear load floor
HEADLAMP HEIGHT ADJUSTER:
Automatic headlamp adjustment
FRONT SEAT GUARD:
Without cab protection panel
FRONT SUN VISOR:
Driver’s+passenger’s side without inscription
STORAGE (DRIVING POSITION):
Closed side storage compartment + bezel
"rd4" rds compact disc audio system
Automatic air conditioning
Regulator or speed limit
DRIVER’S SEAT HEIGHT CONTROL:
Parallel drv height adj
INTERIOR REAR VIEW MIRROR:
Day -night inner rear mirror
CARPET COVER:
Carpet mat 1
DRIVER AIRBAG:
Drivers air bag
LOAD SPACE STORAGE:
With net + removable storage compartment in boot
CARPET:
Needled carpet dilour f550
TUNER RADIO:
Mono radio tuner
INTERIOR PROTECTION:
Without inner protection
OBSTACLE DETECTION SYSTEM:
Front-rear radar obstacle sensor
LATERAL BLINDS:
Without side blinds
Aluminium gear lever knob + leather gaiter
FLOOR MAT:
With carpetmat
EQUALISER AMPLIFIER:
Without equaliser amplifier
Simple + automatic central locking
Standing steering wheel
Without interior child monitoring mirror
Alternator 150 amp
Battery l2 400
Starter motor cl 4
Automatic headlamp illumination
MULTIPLEXING:
Multiplexing assembly can can
Standard
Normal atmosphere
RADIO HEADPHONE SOCKET:
With accessories socket
TRAFFIC SIDE:
Driving on the right-hand side
SIDE IMPACTS:
Door without reinforcement
SET OF KEYS:
1 hf plip key + 1 single main key
EMERGENCY EQUIPMENT:
W/o help equipment
SURFACE CONDITIONS:
Good terrain
SLAVE CONTROL UNIT:
Bsi + com fixed hub steering wheel
EMERGENCY WARNING TRIANGLE:
Without warning triangle
C4 2.0 VTS 177KM VF7LARFKC74161795 Warszawa 2013/12/18 22:55 #53958
  • nelro
  • nelro Avatar
no fajna, dlatego jadę obejrzeć co to auto jest warte:)
ale do pełnej opcji nieco brakuje...;) chociaż ta już jest fajna:)
C4 2.0 VTS 177KM VF7LARFKC74161795 Warszawa 2013/12/19 05:45 #53964
Daj znac jak obejrzysz ;)
C4 2.0 VTS 177KM VF7LARFKC74161795 Warszawa 2013/12/22 18:16 #54067
  • nelro
  • nelro Avatar
Cześć, nie kupiłem i nie kupił bym go nawet za 17500 na które się zgodził, choć się zarzekał że ma 2 oferty jedna za 18000 i drugą za 4500 euro(!!) i dziwię się że jak ma takie oferty to dalej auto wystawia a nie czeka na tego który tyle zaoferował... z tym ze auta pewnie nie widzieli więc...
W skrócie... zawiodłem się, jestem estetą a samochód wymaga poprawek i jak dla mnie zbyt wielu. Uważam że samochodem jeździł ktoś kto o niego nie dbał od samego początku i został na sztukę poprawiony. Wgnieciony tylni prawy błotnik, prawe drzwi dłubane bo skóra była podklejana i źle to zrobiono. Instalacja gazowa założona niechlujnie i bez wyobraźni. Ale właściciel twierdzi że jest ok...:) tylko ze jak mu się jakiś przewód przetrze i zrobi wielkie buuum pod maską to pewnie zmieni zdanie:) Drążek od biegów latał jak pani lekkich obyczajów cycki (nie obrażając nikogo). Ogólnie oglądałem auta po dzwonkach i lepiej zadbane...
Dał bym za niego max 12tyś bo z 5 trzeba by włożyć żeby doprowadzić go do ładu przeze mnie akceptowalnego.
