TEMAT: Corvette Z06 - prośba o sprawdzenie potwora :)
Corvette Z06 - prośba o sprawdzenie potwora :) 2012/10/07 21:08 #31325
  • marcin78
  • marcin78 Avatar
Ostatnie sprawdzenie skńczyło się odkryciem brutalnej prawdy :S może tym razem z Waszą pomocą dowiem się czegoś fajnego :)
1G1YY26E565101503 Sprawdź ten VIN na autobaza.pl ▸
otomoto.pl/show?id=C20981968
Z góry dziękuję !
M. antoxe
Odp: Corvette Z06 - prośba o sprawdzenie potwora :) 2012/10/09 17:35 #31472
1G1YY26E565101503
1G1YY26E565101503
United states
Bowling Green, KY
Chevrolet
Corvette
Two-door
Drzwi:
2-door
Gasoline
P5ED:
Power door locks
V452:
Vehicle anti-theft
A364:
Abs brakes
LE14:
Limited slip differential
T643:
Traction control
V030:
DCC4:
Driver airbag
PA4E:
Passenger airbag
KA70:
Keyless entry
AFD8:
Air conditioning
S7E4:
C469:
Cruise control
TA7F:
Tachometer
T008:
Tilt steering
TC5A:
Tilt steering column
L272:
Leather steering wheel
T114:
Tire pressure monitor
AC08:
Am/fm radio
C354:
Cd player
DE19:
L07A:
Leather seat
AAB8:
Automatic headlights
D835:
Daytime running lights
F98D:
Fog lights
HB91:
High intensity discharge headlights
F4AE:
Front air dam
R9F3:
Rear spoiler
S3E8:
Splash guards
AA42:
Alloy wheels
P38E:
Power windows
HC6B:
Heated exterior mirror
P673:
IC14:
Interval wipers
RE3B:
Rear window defogger
S9CE:
Seat adjuster, power, driver 6-way
C030:
Console, floor, lockable, includes 2 covered cupholders, ashtray with cigar lighter, auxiliary power outlet and CD storage
F00B:
Floormats, carpeted
S4F5:
Steering column, manual, Tilt-Wheel
SA8E:
Steering wheel, leather-wrapped, smaller, 3-spoke
H07E:
Head-Up Display, includes dot-matrix readouts for street mode, track mode with g-meter, vehicle speed, engine rpm, and readings from key gauges including water temperature and oil pressure
I109:
Instrumentation, analog, electronic, includes Driver Information Center with 2 line display
T508:
Tire Pressure Monitor System, air pressure sensors in each tire, pressure display in Driver Information Center
O380:
Oil life monitoring system
D709:
Door locks, power, programmable, includes lockout protection
W869:
Windows, power, includes driver and passenger express-down
C92F:
Cruise control, electronic with set and resume speed
TE0A:
Theft-deterrent system, push button start, immobilizer and audible visual alarm
KB9D:
Keyless Access, with push-button start, includes 2 remote transmitters which enable automatic door unlock and open by touching door switch
HAD8:
Hatch release, push button open
DD43:
Defogger, rear-window, electric
A6BE:
Air conditioning, dual-zone, automatic, includes individual climate settings for driver and right front passenger, automatic climate control and outside temperature display
A036:
Air filtration, includes pollen filter
S188:
Sound system, ETR AM/FM stereo with CD player and MP3 playback, includes Radio Data System, seek-and-scan, digital clock, auto-tone control, automatic volume, Theftlock and (U66) Sound system feature, 7-speaker system
A8D8:
Antenna, integral, hidden
M9FD:
Mirror, inside rearview, manual day/night, includes dual reading lights
VEC6:
Visors, illuminated vanity mirrors, driver and front passenger
L9F4:
Lighting, interior, courtesy, cargo and glovebox
SD67:
Storage, includes lockable glovebox, center console and 2 rear compartments with covers (One compartment contains battery on Z06)
B305:
Brakes, 4-wheel antilock, 4-wheel disc
ABC8:
Air bags, frontal, driver and right front passenger with passenger side suppression (Always use safety belts and proper child restraints, even with air bags. See the Owners Manual for more safety information.)
TA4D:
Traction control, all-speed
D053:
Daytime running lamps
HB3C:
Headlamps, dual projector lamps, xenon high-intensity discharge low-beam, tungsten-halogen high-beam, includes automatic exterior lamp control
FD31:
Fog lamps, front, integral in fascia
MC82:
Mirrors, outside rearview, power, heated, body-color
G6F8:
Glass, Solar-Ray light tinted
WC86:
Wipers, intermittent, front
C532:
City 16/hwy 26 (7.0L engine/6-speed manual trans)
EAB0:
Engine, 7.0L (427 ci) LS7 V8 SFI (505 hp [376.6 kW] @ 6300 rpm, 470 lb.-ft. [634.5 N-m] @ 4800 rpm), includes dry sump oil system
T3B7:
Transmission, 6-speed manual, short-throw (Includes (GU6) Axle, 3.42 ratio.)
A6F1:
Axle, 3.42 ratio, limited slip
R323:
Rear wheel drive
AF88:
Active handling, improves traction and enhances vehicle stability
E82A:
Engine access, rear opening hood, includes underhood lamp
ZD62:
Z06 Performance Package, 4-wheel independent, includes transverse composite springs, power steering, engine oil, axle and transmission coolers, stiffer springs and stabilizer bars, specific shock absorbers, larger brakes with 6 piston front and 4 piston rear cross-drilled rotors and specific tires
T1DD:
Tires, front P275/35ZR18, extended mobility, Eagle F1 Supercar
T3B6:
Tires, rear P325/30ZR19, extended mobility, Eagle F1 Supercar
W463:
Wheels, Z06 silver painted aluminum, 18" x 9.5" (45.7 cm x 24.1 cm), front and 19" x 12" (48.3 cm x 30.48 cm), rear
S1A9:
Steering, power, speed-sensitive, rack and pinion
F86E:
Fuel capacity, approximate, 18 gallon (68 liters)
E1F9:
Exhaust, dual mode, aluminized stainless-steel with polished 4" stainless-steel tips
GALERIA # 0
