TEMAT: Prośba o sprawdzenie: Audi TT 8N- truzzz8nzy1090155
Prośba o sprawdzenie: Audi TT 8N- truzzz8nzy1090155 2013/02/04 12:12 #37438
  • kaczmar
  • kaczmar Avatar
mogę prosić o rozkodowanie vin, sprawdzenie przebiegu itp
nr vin: TRUZZZ8NZY1090155 Sprawdź ten VIN na autobaza.pl ▸
link do aukcji:
otomoto.pl/audi-tt-xenon-serwis-super-stan-C27635877.html
z góry dziękuje za każde uzyskane informacje,
pozdrawiam
Odp: Prośba o sprawdzenie: Audi TT 8N- truzzz8nzy1090155 2013/02/04 13:00 #37444
  • kprzemo24
  • kprzemo24 Avatar
94 TKM w listopadzie 2010 roku
1 0A1 L TUE two doors
2 0AS L STV front stabilizer
3 0BC L STH rear stabilizer
4 0CV L AED vehicle class differentiation 8N0
5 0F2 L KRS fuel system for carburetor gasoline engine
6 0FA L FAD standard manufacturing sequence
7 0G4 L GES cable gearshift
8 0GH L AGM emissions concept D4
9 0L2 L GAB electric throttle actuation
10 0LW L SIZ special plates/stickers/ safety certificates for Germany
11 0N5 L HIA standard rear axle
12 0RA L ZSS without ignition/starter switch locking system
13 0ST L SAU labels/plates in German and French
14 0VC L BTA information kit in German
15 0W1 L AKZ label for central electric German-speaking countries
16 0YC L GKH weight category rear axle weight range 3
17 1AT L BRS electronic stabilization program (ESP)
18 1C1 L FRO antifreeze up to -25 degree celsius tolerance up to -30 degree C
19 1D0 L AHV without towing attachment
20 1E1 L AKB activated carbon canister
21 1EX L TYP special identification plate for EC
22 1G9 L RER space-saving spare wheel for temporary use, radial tire (5-hole)
23 1GS L DFV front shock absorption (AUDI TT)
24 1H0 L BRM without proportioning valve
25 1JE L DFH rear sports shock absorption
26 1KK L BAH disc brakes, rear
27 1LT L BAV disc brakes, front
28 1N4 L LEN power steering (different ratio)
29 1PC L ABR wheel bolts with anti-theft protection (unlockable)
30 1SA L TWU without additional engine guard
31 1T3 L VBK First aid kit with warning triangle
32 1X0 L ATA front wheel drive
33 1Z0 L KRM initial standard fuel filling
34 2A4 L UEA delivery equipment for shipment (transitcoating) with thick seat cover
35 2B1 L GRD additional exterior noise suppression
36 2C5 L LSS axial and vertical adjustable steering column
37 2D1 L CWV complete cd enhancing underbody panel
38 2G9 L EBB filler neck module 2 with insert
39 2K1 L SFS reinforced bumpers
40 2LB L KRB fuel tank with special material treatment (fluorination)
41 2V1 L FRI dust and pollen filter
42 2W0 L TDA fuel filler cap
43 2WA L ZBR without additional tires
44 2Z1 L TYZ type sign at rear and "Quattro" nameplates respectively
45 2ZN L LRA leather trimmed sports steering wheel with aluminum appearance
46 3B0 L ZKV without additional child seat anchor
47 3FA L DEI without roof insert (standard roof)
48 3H5 L LER backrest release for front seats with additional backrest release on the innerside
49 3L3 L SIE manual height adjustment for front seats
50 4A3 L SIH seat heater for front seats separately controlled
51 4E6 L SDH tailgate/trunk lid release from inside only
52 4GH L WSS windshield tinted with windshield sunshield
53 4K4 L TKV radio remote controlled central locking operated from inside and separate trunk release
54 4M0 L BEH without cup holder
55 4P0 L PBH rear floor panel module, type 1
56 4R1 L FEH power windows
57 4SD L MSL left vanity mirror illuminated
58 4TD L MSR right vanity mirror illuminated
59 4UF L AIB driver's and front passenger airbag with front passenger airbag deactivation
60 4X1 L SAB side airbag front
61 5C0 L KSA without special body measures
62 5D1 L TRF carrier frequency 433.92 MHz
63 5F0 L HTP without hardtop
64 5J1 L HES rear spoiler
65 5K5 L LAC transit protective film (instead of paint preservative)
66 5RU L ASR outer right rear view mirror: convex (large viewing field)
67 5SL L ASL outer left rear view mirror: non-spherical
68 6E0 L MAS without center armrest front
69 6N0 L SZF without mud flaps
70 6PA L HBV plastic hand brake lever handle
71 6Q7 L SAG leather gearshift knob with aluminum appearance
72 6R3 L SHV rubber gearshift boot
73 6V1 L HEB rear trim panel (ECE)
74 6W5 L KZV front license plate bracket
75 6XD L ASE outer rear view mirrors: powered, heated
76 7A0 L CDW without CD changer/CD player
77 7AA L EDW electronic vehicle immobilization device
78 7CA L AKF without label for radio remote control
79 7E0 L WSA w/o heat accumulator/auxiliary heating
80 7L0 L SNA without inertia benefit system/ deceleration fuel cut-off/idle stop valve
81 7P0 L LOR without lumbar support in front and rear seats
82 7Q0 L NAV without navigation device
83 7QA L CDR without CD ROM
84 7S0 L WIN without wind blocker
85 7X0 L EPH without park distance control (parking pilot)
86 8CC L TWP speedometer sensor without seal (electronic speedometer sensor)
87 8GL L GEN alternator 120A
88 8JG P HSW headlight with gas discharge lamp for driving on the right
89 8K0 L FLS without special low beam mode
90 8M0 L HEW w/o rear window wiper and washer system
91 8N4 L SWS windshield wiper intermittent control with potentiometer (four speeds)
92 8Q2 P LWR automatic headlight-range adjustment static
93 8T0 L GRA without cruise control system (CCS)
94 8TC L NEL rear fog light for driving on the right
95 8UD P RAO radio "concert"
96 8W1 P WWA washer fluid level indicator
97 8X1 P SWR headlight washer system
98 8Y1 L SNH two-tone horn
99 8Z5 L MKU engine cooling system, type 1
100 9AK L HKA "Climatronic" with impact pressure control free of cfc
101 9D0 L VEF without preparation for two-way radio installation
102 9JD L RAU smoking version, ashtray front
103 9M0 L ZUH without auxiliary/parking heater
104 9P0 L SGK without seat belt warning light
105 9Q2 P MFA multi-function indicator/on-board computer with check control
106 9T1 L BWD heated washer nozzles, front
107 9U1 L BVK brake pad wear indicator
108 9VD P LSE speaker (active)
109 9Y1 L ATE outdoor temperature gage
110 9ZF E VTV preparation for cellular phone with hands-free speaking system
111 A00 L SAH no self-collection
112 A8S I AUS standard equipment
113 B0A L BLB component parts set without country-specific design requirement
114 B99 L TPL type approval EC
115 C05 E COC operating permit, alteration 5
116 C4M L RAD alloy wheels 7J x 16 5-arm style, offset 31
117 E0A L AAU no special edition
118 F0A L FZS no special purpose vehicle, standard equipment
119 FA0 L SVO control of standard production
120 FC0 L IND without customized installation
121 G0C I GSP 5-speed manual transmission
122 HA4 L REI Tires 205/55 R 16 W
123 J1L L BAT battery 280 A (60 Ah)
124 K8C I KAR Coupe
125 L0L L LEA left-hand drive vehicle
126 MQ7 L MOT 4-cyl. gasoline engine 1.8 L/132 kW 20V turbo base engine is T8C/T16
127 N7U L SIB Alcantara/pearl napa leather seat cover.
128 PI1 G Driver Information System (DIS)
129 PX1 G xenon headlights
130 Q1D L VOS sports front seats
131 QG1 L WIV service interval prolongation
132 QV0 L TVE w/o TV reception/digital radio reception
133 RCL G "concert" radio
134 T8C I GMO 4-cylinder gasoline engine 1.8 L unit 06A.C
135 U2A L INS instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
136 U99 L GKV suspension range 198
137 V0A L REL tires w/o specification of tire brand
138 VC0 L GRT w/o remote-controlled garage door opener
139 X0A G national sales program Germany
Odp: Prośba o sprawdzenie: Audi TT 8N- truzzz8nzy1090155 2013/02/04 21:41 #37474
