Tak jak w temacie proszę o sprawdzenie, wiem że auto nie jest pierwszej młodości, ale każde info się dla mnie liczy bo znajomy się uparł na zakup. Auto nie jest nigdzie wystawione na serwisach aukcyjnych
Numer VIN - WVWZZZ50ZPK002191 Sprawdź ten VIN na autobaza.pl ▸
Region - Germany Fabryka / Producent - Osnabruck Marka - Volkswagen Model - Corrado\nRok - 1992 Silnik - 2.00 [100kW] [136HP] [4cyl.] Numer seryjny - 002191 Vehicle identification no. - Wvwzzz50zpk002191 Model designation - Corrado Date of production - 02.09.1992 Model year - 1993 Sales type - 509034 Engine code - 9A Transmission code - Axle drive - Interior trim code - RW Roof color - J9 Exterior color/paint code - J9/c5u Engine type - tyle narazie. Na reszte trzeba poczekac |
Region - Germany Fabryka / Producent - Osnabruck Marka - Volkswagen Model - Corrado\nRok - 1992 Silnik - 2.00 [100kW] [136HP] [4cyl.] Numer seryjny - 002191 Vehicle identification no. - Wvwzzz50zpk002191 Model designation - Corrado Date of production - 02.09.1992 Model year - 1993 Sales type - 509034 Engine code - 9A Interior trim code - RW Roof color - J9 Exterior color / paint code - J9 / c5u Activated carbon canister - Activated carbon canister Additional dust seals - Without additional seals outside Additional instruments - Without additional instruments/switches Anti-theft protection system - Without anti-theft protection system Antifreeze - Antifreeze up to -25 degree celsius tolerance up to -30 degree c Automatic transmission indicator light - Without automatic transmission indicator light Base engine - 4-cylinder gasoline engine 2.0 l unit 051.3 Batteries - Battery 280 a (60 ah) Body style - Coupe Brackets - Without bracket for first aid kit and warning triangle Brake pad wear indicator - Without brake pad wear indicator Braking systems - Anti-lock brake system (abs) Cassette and cd storage unit - Without cassette and cd storage unit Catalytic converter control - without catalytic converter warning light Center high-mounted stop light - Without center high-mounted stop light Child seat anchor, front - Child seat anchor, front left (isofix) Climatic zones - Standard climatic zones Component part sets with country-specific design requirements - Component parts set, complying with vehicle type for italy, various parts Components with special surface appearance - Components without special surface appearance Cruise control - Without cruise control system (ccs) Decorative films / emblems - Without decorative films / emblems Door and lid locking system - Central locking system Door and side trim panels - Door and side trim panel in foam film and woven fabric with decorative stripes Electric safety package - without additional electric safety package Engine specifications - 4-cyl. gasoline engine 2.0 l/100 kw 16v closed-loop catalytic converter base engine is t5j Equipment levels - Comfort sports equipment Exterior noise suppression measures - Without additional exterior noise suppression First aid kit / warning triangle - Without first aid kit and warning triangle Front fog light/additional headlight - Integrated front fog light Front license plate carrier - Without license plate carrier front Front seats - Sports front seats Front spoiler - Front spoiler Fuel quantity for initial filling - Initial standard fuel filling Fuel tank vent line - Fuel tank vent line with gravity valve and pvc breather hose Gearshift boot/cover - Leatherette gearshift boot Gearshift knob/handle - Plastic gearshift knob/handle Generators - Alternator 90a Hand brake lever handle - Plastic hand brake lever handle Headlight - Halogen headlight for driving on the right Headlight activation - Without special headlight activation mode but with coming and leaving home function Headlight washer system - Without headlight washer system Headlight-range adjustment - Without headlight-range adjustment Heated washer nozzles - Heated washer nozzles, front Heating and air conditioning system - Manually controlled air conditioning Identification plates - Special identification plate (italy) Ignition/starter switch locking system - Without ignition/starter switch locking system Insert for the filling up of unleaded fuel/fuel type - Insert for the filling up of unleaded fuel Instrument inserts - Instrument insert with tachometer clock and km/h speedometer Left exterior mirror - Left exterior mirror flat, electrically adjustable and heated Lockable wheel bolts - Standard wheel bolts Malfunction display - Without additional malfunction display Outer rear seat belts - 3-point seat belts, outer rear with ece label Paint preservative/transit coating - Paint preservative (wax) Park distance control - Park distance control, front and rear with rear view camera Protective side molding - Protective side molding Radiator grille - Radiator grille Radios - Without radio Rear fog light - Rear fog light for driving on the right Rear license plate carrier - License plate carrier rear (ece) Rear seats - Rear seat bench unsplit, backrest split folding (three pieces) with center armrest Restraint systems, front - 3-point seat belts, front Right exterior mirror - Right exterior mirror convex, electrically adjustable and heated Roof insert/convertible top - Electric sliding/pop-up sunroof Seat adjustment - Manual height adjustment for front seats Seat belt check - Without seat belt reminder Seat covering - Seat coverings in flat woven fabric Seat heater - Without seat heater Shock absorption/suspension, chassis - Standard suspension/shock absorption Side and rear windows - Side and rear windows in heat-insulating glass Side lights - Side turn signal lights Spare wheel/breakdown set - Space-saving spare wheel Speaker installation - 6 speakers (passive) Special editions - No special edition Speedometer cable and seal - Speedometer sensor without seal (electronic speedometer sensor) Steering column systems - Height adjustable steering column Steering system arrangement - Left-hand drive vehicle Steering wheels - Sports steering wheel (hollow rim) Telephone/telematics - without car phone preparation/installation Tire suppliers - Tires with o specification of tire brand Tires - Tires 195/50 r15 v Towing eyes - One towing eye each side, front and rear Trailer hitch - Without trailer hitch Transmission specifications - 5-speed manual transmission Vehicle class differentiation units/platform components - Vehicle class differentiation -4v0 Wheels - Steel wheels 7.50 x 20 (eight-hole) Window regulator - Power windows Windshield glass type - Windshield in heat-insulating glass |
190 tys km w 2008 roku. Bankowo KOREKTA!
hehe a skad wiesz ze korekta jak nie ma tu podanej aukcji i przebiegu?
