TEMAT: polo - WVWZZZ6NZWW142019
polo - WVWZZZ6NZWW142019 2012/09/04 14:56 #29643
  • Grześ
  • Grześ Avatar
witam wszystkich.
prosze o sprawdzenie wv POLO vin WVWZZZ6NZWW142019 Sprawdź ten VIN na autobaza.pl ▸
z góry dziękuje za jakiekolwiek informacje o tym aucie.
Odp: polo - WVWZZZ6NZWW142019 2012/09/04 21:23 #29663
WVWZZZ6NZWW142019
WVWZZZ6NZWW142019
Germany
Wolfsburg
VOLKSWAGEN
Polo
1.60 [55kW] [75HP] [4cyl.]
Vehicle Identification No.:
WVWZZZ6NZWW142019
Model Designation:
polo
Date of production:
03.04.1998
Model year:
1998
Sales type:
6N10C4
Engine code:
AEE
Transmission code:
DKE
Axle drive:
5S
Interior trim code:
EP
Roof color:
B4
Exterior color/Paint Code:
B4/B9A
Activated carbon canister:
Additional body covers, side:
Without additional side body covers(stone guard)
Without additional child seat anchor
Without additional tires
Air bag:
Air bag for driver and front seatpassenger
Antifreeze:
Antifreeze up to -25 degree celsiustolerance up to -30 degree C
Backrest release:
Backrest release for front seat(s)
Batteries:
Battery 280 A (60 Ah)
Body measures:
Without special body measures
Body style:
Hatchback
Brake type, front:
Disc brakes, front
Brake type, rear:
Drum brakes, rear
Braking systems:
Anti-lock brake system (ABS)
Bumper:
Painted bumpers
Catalytic converter control:
W/o catalytic converter warning light
Center high-mounted stop light:
Center rear seat belts:
Static lap belt, center rear
Climatic zones:
Standard climatic zones
Clutch actuation:
Mechanical clutch actuation
Component parts set withoutcountry-specific design requirement
Cruise control warning and speed limit system:
Without cruise control warning system
Cup holder:
Without cup holder
Dashboard:
Standard dashboard
Door and lid locking system:
Central locking system
Door and side trim panels:
Doors:
2 doors
Duty-free tires:
Without duty-free and cost-free tires
Engine specifications:
4-cylinder gasoline engine 1.6 L/55 kWw/ MPI, MVEG 2 a. closed-loop cat. conv.base engine is T3N
Equipment levels:
Comfort equipment
Exterior noise suppression measures:
Additional exterior noise suppression
Without first aid kit and warningtriangle
Flame retardent materials:
No flame retardent materials
Floor mats:
Without floor mats
Front cargo area:
Without cargo area front
Integrated front fog light
Front stabilizer:
Front stabilizer
Front turn signal lights:
Yellow turn signal lights
Initial standard fuel filling
Fuel systems:
Fuel system for carburetor gasolineengine
Fuel tank treatment:
Fuel tank with special materialtreatment
Gearshift boot/cover:
Rubber gearshift boot
Gearshift knob/handle:
Plastic gearshift knob/handle
Operating permit, alteration
Generators:
Alternator 90A
Hand brake lever handle:
Plastic hand brake lever handle
Headlight:
Halogen headlightfor driving on the right
Headlight activation:
Without special headlightactivation
Headlight washer system:
Without headlight washer system
Headlight-range adjustment:
W/o heat accumulator/auxiliary heating
Heated washer nozzles:
Heated washer nozzles, front
Manually controlled air conditioning
Identification plates:
Special identification plate for ECfor M1 passenger vehicle
Without ignition/starter switch lockingsystem
Insert for the filling up of unleadedfuel
Interference suppression:
Local interference suppression for FMradio reception
Key for locking system:
Key without LED
Left exterior mirror:
Left exterior mirror aspherical,electrically adjustable and heated
Luggage compartment cover:
Foldable trunk cover
Luggage compartment floor covering:
Flat needle-punched trunk floor covering
Wolfsburg manufacturing sequence
Mud flap:
Without mud flaps
Nameplate set:
Nameplate set in base trim
Navigation device:
Without navigation device
Outer rear seat belts:
3-point seat belts, outer rear with ECElabel
Without surface protection, withadditional transit coating
Partition:
Without partition
Protective side molding:
Radios:
Radio alpha Europa
Rear cargo area:
Without cargo area
Rear fog light:
Rear fog light for driving on the right
Rear headrests:
Rear headrests
Rear seats:
Rear seat bench/backrest, split folding
Rear spoiler:
Rear spoiler
Rear stabilizer:
Without rear stabilizer
Restraint systems, front:
3-point seat belts with tensioner andheight adjustment, front
Right exterior mirror:
Right exterior mirror convex,electrically adjustable and heated
Roof insert/convertible top:
Without roof insert (standard roof)
Seat adjustment:
Seat belt check:
Without seat belt reminder
Seat covering:
Woven fabric seat covering
Seat heater:
Seat heater for front seatsseparately controlled
Second battery/battery installation:
Without second battery
Side air bag:
Without side air bag
Side and rear windows:
Side and rear windows in heat-insulatingglass
Side lights:
Side turn signal lights
Spare wheel/breakdown set:
Space-saving spare wheel
Speaker installation:
2 speakers (passive)
Special color trim:
Without special color trim
Special editions:
No special edition
Special labels/plates:
Labels/plates in German
Speedometer cable and seal:
Speedometer sensor without seal(electronic speedometer sensor)
Start/stop system/regenerative braking:
Without inertia benefit system/deceleration fuel cut-off/idle stopvalve
Steering:
Power steering
Steering system arrangement:
Left-hand drive vehicle
Steering wheels:
Steering wheel for air bag system
Sticker (customized or special edition):
Without stickers and badges
Taillight assemblies:
Taillight assemblies, standard design
Tires:
Tires 235/45 R18 94W(polymer coating)
Transmission specifications:
5-speed manual transmission
Type approval Germany
Vehicle class differentiation 6N0
Vehicle specifications:
No special purpose vehicle, standardequipment
Wheel covers:
Wheel center cover
Wheels:
Alloy wheels 6J x 17
Window regulator:
Power windows
Windshield glass type:
Windshield in heat-insulating glass
Front seats:
Standard front seats with integratedstorage trays
Base engine:
4-cylinder gasoline engine 1.6 Lunit 032.2
Instrument inserts:
Instrument insert with tachometerclock and km/h speedometer
Tire suppliers:
