TEMAT: Prośba o sprawdzenie passat b5
Prośba o sprawdzenie passat b5 2012/06/28 11:56 #27272
  • gentki
  • gentki Avatar
tak jak w temacie proszę o sprawdzenie, vin pojazdu WVWZZZ3BZYE281023 Sprawdź ten VIN na autobaza.pl ▸
Odp: Prośba o sprawdzenie passat b5 2012/06/28 18:49 #27283
Dekodowanie numeru VIN WVWZZZ3BZYE281023 na www.automo.pl
Vehicle Identification No.: WVWZZZ3BZYE281023
Model Designation: passat estate
Date of production: 02.02.2000
Model year: 2000
Sales type: 3B53A5
Engine code: ANA
Transmission code: DWG
Axle drive: 5S
Interior trim code: GP
Roof color: K1
Exterior color/Paint Code: K1/A5E
Activated carbon canister: [1E1] : Activated carbon canister
Additional body covers, side: [6EP] : Additional stone guard body covers
Additional child seat anchors: [3B4] : Child seat anchor forchild seat system ISOFIX
Additional dust seals: [6U0] : Without additional seals outside
Additional tires (winter tires): [2XE] : Winter tires 195/65 R 15 91T withsteel wheel 6J x 15, offset 45 (5-hole)without full wheel cover (C0V)
Alternative drive module: [0K0] : Without alternative drive module
Antennas: [8L3] : Roof antenna
Anti-theft protection system: [7AB] : Electronic alarm system with vehicleimmobilization device (for RoW)
Automatic transmission indicator light: [9FA] : Without automatic transmissionindicator light
Auxiliary heating: [9M0] : Without auxiliary/parking heater
Batteries: [J1P] : Battery 220 A (44 Ah)
Body measures: [5C0] : Without special body measures
Body style: [K8D] : Station Wagon Variant/Avant
Brake type, front: [1ZJ] : Disc brakes, front (Geomet D)
Braking systems: [1AT] : Electronic stabilization program (ESP)
Breakaway interior mirror: [4L2] : Dipping breakaway interior rear viewmirror
Bumper: [2JB] : Standard bumpers
CD ROM/DVD/SD card: [7QA] : Without CD/DVD for navigation
CD changer/CD player: [7A2] : CD changer
Cassette and CD storage unit: [4W0] : Without cassette and CD storage unit
Catalytic converter control: [8KA] : W/o catalytic converter warning light
Center high-mounted stop light: [8R1] : Center high-mounted stop light
Center rear seat belts: [3C3] : Lap belt with retractorfor the center rear seat
Controls (steering wheels/steering column): [4LA] : Without controls
Cruise control: [8T0] : Without cruise control system (CCS)
Cruise control warning and speed limit system: [6Y0] : Without cruise control warning system
Cup holder: [4M6] : Cup holder
Door and lid locking system: [4K3] : Radio remote controlled central lockingoperated from inside and safe securing
Door and side trim panels: [3LD] : Door and side trim panel
Drive layout: [1X0] : Front wheel drive
Duty-free tires: [1V0] : Without duty-free and cost-free tires
Emission standard: [0GH] : Emission standard D4
Engine specifications: [MQ5] : 4-cylinder gasoline engine 1.6 L/74 kWwith multi-point injection and D4base engine is T6U
Equipment levels: [A8S] : Standard equipment
Exterior mirror setting: [6XN] : Exterior mirrors: electricallyadjustable, separately heated
Exterior noise suppression measures: [2B0] : Without additional exterior noisesuppression
Fire extinguisher: [6A0] : Without fire extinguisher
First aid kit / warning triangle: [1T2] : Warning triangle
Flame retardent materials: [4Q0] : No flame retardent materials
Floor coverings: [3MQ] : Ibolours floor covering
Floor mats: [0TA] : Without floor mats
Front fog light/additional headlight: [8WD] : Integrated front fog light
Front license plate carrier: [6W1] : License plate carrier front (large)
Gearshift boot/cover: [6R1] : Leatherette gearshift boot
Gearshift knob/handle: [6Q1] : Plastic gearshift knob/handle
General operating permit, alterations: [C13] : Operating permit, alteration
Generators: [8GD] : Alternator 90A
Hand brake lever handle: [6PA] : Plastic hand brake lever handle
Headlight: [8JM] : Twin headlight for driving on the right,with integrated high beam
Headlight washer system: [8X0] : Without headlight washer system
Headlight-range adjustment: [8Q1] : Headlight-range adjustment
Headrests: [3J7] : Articulated and height-adjustableheadrests for front seats
Heat accumulator system/additional heater: [7E0] : W/o heat accumulator/auxiliary heating
Heated washer nozzles: [9T1] : Heated washer nozzles, front
Heating and air conditioning system: [9AB] : Manually controlled air conditioning
Insert for the filling up of unleaded fuel/fuel type: [2G1] : Insert for the filling up of unleadedfuel
Inserts: [5MA] : Decorative inserts
Installation parts for engine (engine mount system): [1VG] : Installation parts for four-cylinderengine
Interference suppression: [8E2] : Local interference suppression for FM/AMradio reception
Left vanity mirror: [4SD] : Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid: [4E0] : Tailgate/trunk lid unlockingfrom outside
Lockable wheel bolts: [1PA] : Standard wheel bolts
Luggage compartment floor covering: [6SL] : Tufted trunk floor covering (cut pile)
Luggage net/pocket on backrest(s): [4U5] : Luggage pockets on backrest
Lumbar support: [7P4] : Manually adjustable lumbar support infront seats
Malfunction display: [9HA] : Without additional malfunction display
Moldings: [4ZE] : Black moldings
Multi-function display/trip computer: [9Q1] : Multi-function display/on-board computer
Nameplate set: [0NA] : Without nameplate set(without model designation)
Outdoor temperature gage: [9Y1] : Outdoor temperature gage
Paint preservative/transit coating: [5K0] : Without surface protection, withadditional transit coating
Park distance control: [7X0] : Without park distance control
Parking light indicator light: [8NA] : Without parking light warning light
Partition: [3CX] : Net partition
Platform module floor pan, rear: [4P1] : Rear floor panel module, type 2
Preparation for sound combination for rotating emergency light: [9F0] : Without sound combination for rotatingemergency light and radio antennapreparation
Protective side molding: [4B1] : Protective side molding
Radios: [8AD] : Radio "gamma"
Reading light: [8S4] : Two reading lights front, two rear
Rear cargo area: [3GK] : Without additional lower part forluggage compartment floor
Rear headrests: [3Q1] : Rear headrests
Rear seat catch: [6QA] : Rear seat catch
Rear seats: [3NW] : Rear seat bench/backrest, split foldingwith center armrest
Right exterior mirror: [5RQ] : Right exterior mirror: convex
Right vanity mirror: [4TD] : Right vanity mirror illuminated
Roll-up sun screen for rear and side windows: [3Y0] : Without roll-up sun screen
Roof rails/roof load rack: [3S2] : Black roof rails
Safety certificate: [0LA] : Without special plates/stickers/safety certificates
Seat covering: [N0U] : Cut pile seat covering
Shock absorption/suspension, chassis: [1BA] : Standard suspension/shock absorption
Side air bag: [4X1] : Side air bag front
Side lights: [8F2] : Side turn signal lights
Ski bag: [3X0] : Without load-through provision
Socket: [7B2] : 12-volt socket in luggage boot
Spare wheel/breakdown set: [1G2] : Steel spare wheel with originalequipment tires
Speaker installation: [8RM] : 8 speakers (passive)
Special alarm systems: [9A0] : Without taxi alarm system
Special labels/plates: [0SB] : Labels/plates in German
Steering wheels: [2PQ] : Steering wheel for air bag system
Sticker (customized or special edition): [0KA] : Without stickers and badges
Supertone system and tone sequence control: [9J0] : Without supertone system and tonesequence control
Taillight assemblies: [8SA] : Taillight assemblies, standard design
Telephone/telematics: [9W0] : W/o car phone preparation/installation
Throttle actuation: [0L2] : Electric throttle actuation
Tire pressure warning light: [7K0] : Without tire pressure warning light
Tires: [H6S] : Tires 195/65 R15 V
Transmission shafts: [1WB] : Transmission shafts w/ 100 mm indiameter
Transmission shafts, rear axle: [1YA] : Without transmission shafts f. rear axle
Transmission specifications: [G0C] : 5-speed manual transmission
Transmission types/gearshift mechanisms: [0G1] : Gearshift lever
Type approval countries/countries with special requirements: [B01] : Type approval Germany
Vehicle class differentiation units/platform components: [0DE] : Installation differentiation for buildstatus of vehicle class B5 (VW Passat)
Weight category front axle: [0JD] : Weight category front axleweight range 4
Weight category rear axle: [0YE] : Weight range 5installation control only, norequirement forecast
Wheels: [C0V] : Steel wheels 6J x 15
Window regulator: [4R3] : Power windows with comfort operation
Windshield glass type: [4GH] : Windshield in heat-insulating glasswith sunshield
Windshield wiper intermittent control: [8N4] : Windshield wiper intermittent controlwith potentiometer (four speeds)
Child seats: [QA0] : Without child seat
Front seats: [Q2J] : Comfort front seats
Service interval prolongation: [QG1] : Service interval prolongation
Base engine: [T6U] : 4-cylinder gasoline engine 1.6 lunit 06B.1 (ALU)
Instrument inserts: [U0C] : Instrument insert with tachometerclock and km/h speedometer
