TEMAT: Proszę o sprawdzenie auta WVWZZZ6RZAY169615
Proszę o sprawdzenie auta WVWZZZ6RZAY169615 2012/01/16 21:42 #20896
  • Mikola10
  • Mikola10 Avatar
Odp: Proszę o sprawdzenie auta WVWZZZ6RZAY169615 2012/01/16 22:05 #20903
Dekodowanie numeru VIN WVWZZZ6RZAY169615 na www.automo.pl
Vehicle Identification No.: WVWZZZ6RZAY169615
Model Designation: polo
Model: PO
Date of production: 21.01.2010
Model year: 2010
Sales type: 6R1224
Engine code: CAYB
Transmission code: KFK
Axle drive: 5S
Interior trim code: BY
Roof color: B4
Exterior color/Paint Code: B4/B9A
"Multimedia", video/DVD/notebook connection: [9WC] : Without "Multimedia" in vehicle
Activated carbon canister: [1E0] : Without activated charcoal canister
Additional body covers, side: [6EA] : Without additional side body covers(stone guard)
Additional child seat anchors: [3B3] : Child seat anchor
Air bag: [4UF] : Driver's and front passenger air bagwith front passenger air bagdeactivation
Air cleaner (engine): [1L0] : Standard air cleaner
Air duct, front area: [VK0] : Air duct, standard
Antennas: [8ZG] : Antenna for AM/FM reception
Anti-theft protection system: [7AA] : Electronic vehicle immobilization device
Backrest release: [3H0] : Without backrest release for front seats
Batteries: [J0N] : Battery 330 A (61 Ah)
Battery/alternator capacity: [NY0] : Standard battery/alternator capacity
Body measures: [5C6] : Additional body measures
Body style: [K8G] : Hatchback
Brackets: [3P1] : Bracket for first aid kit and warningtriangle
Brake pad wear indicator: [9U0] : Without brake pad wear indicator
Brake type, front: [1ZG] : Disc brakes, front (Geomet D)
Brake type, rear: [1KT] : Disc brakes, rear (Geomet D)
Braking systems: [1AT] : Electronic stabilization program (ESP)
Breakaway interior mirror: [4L2] : Dipping breakaway interior rear viewmirror
Bumper: [2JF] : Painted bumpers
CD ROM/DVD/SD card: [7QA] : Without CD/DVD for navigation
CD changer/CD player: [7A0] : Without CD changer/CD player
CO2 variant: [0C0] : Standard
Center armrest: [6E0] : Without center armrest front
Center rear seat belts: [3C7] : 3-point seat belt for center rear seat
Components with special surface appearance: [6FA] : Components without special surfaceappearance
Controls (steering wheels/steering column): [4LA] : Without controls
Cruise control: [8T2] : Cruise control system (CCS)electronic
Cruise control warning and speed limit system: [6Y0] : Without cruise control warning system
Cup holder: [4M0] : Without cup holder
Customized installation: [FC0] : Without customized installation
Dashboard: [4N0] : Standard dashboard
Dashboard illumination: [7V1] : Standard dashboard illumination
Delivery equipment: [2A0] : Without delivery equipment
Door and lid locking system: [4K3] : Radio remote controlled central lockingoperated from inside and safe securing
Door and side trim panels: [4AP] : Door and side trim panel
Doors: [0A2] : 4 doors
Emission standard: [7MG] : Emission standard EU5
Engine specifications: [D36] : 4-cyl. turbo dies. eng. 1.6 l/66 kW (4V)TDI common railBase engine is TF3/TJ1
Equipment levels: [A8C] : Comfort equipment
Exhaust tailpipe: [0P2] : Exhaust tailpipe with trim
Exterior mirror setting: [6XD] : Exterior mirrors: electricallyadjustable/heated
Fire extinguisher: [6A0] : Without fire extinguisher
First aid kit / warning triangle: [1T0] : Without first aid kit and warningtriangle
Floor mats: [0TA] : Without floor mats
Fresh air intake for passenger compartment (with particulate filter): [2V5] : Fresh air intake system with activatedcharcoal canister
Front fog light/additional headlight: [8WH] : Front fog lamp and cornering lamp
Front license plate bracket: [6W1] : License plate bracket front (large)
Front stabilizer: [0AQ] : Front stabilizer
Fuel systems: [0F6] : Fuel system for turbo diesel engine withdirect injection (TDI)
Fuel tank treatment: [2LB] : Fuel tank with special materialtreatment
Gearshift boot/cover: [6R1] : Leatherette gearshift boot
Gearshift knob/handle: [6Q1] : Plastic gearshift knob/handle
General operating permit, alterations: [C04] : Operating permit, alteration
Generators: [8GU] : Alternator 140 A
Hand brake lever handle: [6PA] : Plastic hand brake lever handle
Headlight: [8BB] : Halogen headlightfor driving on the right
Headlight activation: [9I0] : Dipped beam headlights as daytimerunning lights
Headlight washer system: [8X0] : Without headlight washer system
Headlight-range adjustment: [8Q1] : Headlight-range adjustment
Headrests: [3J1] : Height-adjustable headrests for frontseats
Heat accumulator system/additional heater: [7E6] : Electric auxiliary air heater
Heated washer nozzles: [9T0] : Without heated washer nozzles
Heating and air conditioning system: [9AP] : Climatic air-conditioning system(semi-automatic)
Horns: [8Y4] : High-sounding horn
Insert for the filling up of unleaded fuel/fuel type: [2G5] : Filler neck module 1 without insert
Installation differentiation for vehicle components: [0EJ] : Installation differentiation fortransmission MQ 250vehicle components
Interior light in driver compartment: [9GA] : Interior light with door pillar switches
Interior light in foot area: [6T0] : Without interior light in footwell
Interior noise suppression measures: [3W3] : Special interior noise suppression
Left vanity mirror: [4SC] : Left vanity mirror with cover
Lockable wheel bolts: [1PA] : Standard wheel bolts
Luggage compartment cover: [3U1] : Foldable trunk cover
Luggage compartment floor covering: [6SC] : Tufted trunk floor covering
Luggage compartment lighting: [9E1] : Luggage compartment lighting
Luggage compartment lining: [5A6] : Full fleece trunk lining
Luggage net/pocket on backrest(s): [4U0] : Without luggage nets/pocketson backrests
Lumbar support: [7P0] : Without lumbar supportin seat backrests
Manufacturing sequence differentiation: [0FB] : Pamplona manufacturing sequence
Mass damper for steering wheels: [1Q0] : Without mass damper for steering wheel
Molding roof liner: [6NA] : Unsplit molding roof liner
Multi-function display/trip computer: [9Q1] : Multi-function display/on-board computer
Nameplate set: [1DG] : Nameplate set "TDI"
Outer rear seat belts: [3ZB] : 3-point seat belts, outer rear with ECElabel
Owner's manuals: [0VB] : Information kit in French
Paint preservative/transit coating: [5K7] : Transport protection film (minimumprotection) with additional transportprotection measures
Park distance control: [7X0] : Without park distance control
Pedal cluster: [VF0] : Standard pedal cluster
Pedestrian protection: [VL1] : Extended pedestrian protection measures
Platform group class: [7PA] : Platform group class 1
Platform module floor pan, rear: [4P2] : Rear floor panel module, type 3
Radiator grille: [6KA] : Radiator grille
Radios: [8UA] : Radio with CD player
Reading light: [8S0] : Without reading light
Rear axle: [0N2] : Heavy-duty rear axle
Rear cargo area: [3GD] : Plane rear cargo area
Rear headrests: [3Q6] : Three rear headrests
Rear license plate bracket: [6P1] : License plate bracket rear (ECE)
Rear seats: [3NC] : Rear seat bench/backrest, split folding
Rear stabilizer: [0BA] : Without rear stabilizer
Rear window wiper and washer system: [8M1] : Rear window wiper and washer systemwith intermittent control
Refrigerator: [1W2] : Glove compartment cooling system
Restraint systems, front: [4QV] : 3-point seat belts with electrictensioner and height adjustment, front
Right exterior mirror: [5RQ] : Right exterior mirror: convex
Right vanity mirror: [4TC] : Right vanity mirror with cover
Roof rails/roof load rack: [3S0] : Without roof rails/roof load rack
Scuff plates: [7M5] : Without protective film for scuff plate
Seat adjustment: [3L1] : Manual height adjustment for left frontseat
Seat belt check: [9P3] : Seat belt reminder, electric contact inbuckle
Seat covering: [N0V] : Fabric seat covering
Seat heater: [4A0] : Without seat heater
Shock absorption, chassis, front: [G09] : Front shock absorption
Shock absorption, chassis, rear: [1JP] : Rear shock absorption
Side air bag: [4X1] : Side air bag front
Smoking/non-smoking package: [9JD] : Smoking package, ashtray front
Socket: [7B2] : 12-volt socket in luggage boot
Spare wheel/breakdown set: [1G2] : Steel spare wheel with originalequipment tires
Speaker installation: [8RE] : 4 speakers (passive)
Special labels/plates: [0SS] : Labels/plates in English and French
Special registration measures: [3M0] : Without special measures
Start/stop system/regenerative braking: [7L3] : Without start/stop system withoutregenerative braking
Steering: [1N2] : Power steeringelectro-hydraulic
Steering column systems: [2C5] : Axial and vertical adjustable steeringcolumn
Steering wheels: [1ME] : Steering wheel
Sticker (customized or special edition): [0KA] : Without stickers and badges
TV reception/digital radio reception: [QV0] : W/o TV reception/digital radio reception
Taillight assemblies: [8SG] : Standard taillight assemblies (type 2)
Telephone/telematics: [9W0] : W/o car phone preparation/installation
Tire pressure warning light: [7K6] : Flat tire indicator
Tires: [H8E] : Tires 185/60 R15 84T
Tool kit and jack: [1S1] : Tool kit and jack
Transmission specifications: [G0C] : 5-speed manual transmission
Trunk sill protection: [2P1] : Plastic trunk sill protection
Type approval countries/countries with special requirements: [B08] : Type approval France
Vehicle class differentiation units/platform components: [0DF] : Vehicle class differentiation 6R0-for build status Europe
Vehicle type: [AZ0] : Vehicle with standard production scope
Washer fluid level indicator: [8W0] : Without washer fluid level indicator
Weight category front axle: [L40] : Suspension range 40installation control only, norequirement forecast
Weight category rear axle: [0YD] : Weight range 4installation control only, norequirement forecast
Wheel covers: [1NJ] : Full wheel covers
Wheels: [C0V] : Steel wheels 6J x 15
Window regulator: [4R2] : Power windows front, mechanical windowregulators rear
Windshield wiper intermittent control: [8N4] : Windshield wiper intermittent controlwith potentiometer (four speeds)
Chrome work package: [QJ0] : Without aluminum/chrome work package
Drawers under front seats: [QN0] : Without drawers under front seats
Front seats: [Q1A] : Standard front seats
Service interval prolongation: [QG1] : Service interval prolongation
Base engine: [TF3] : 4-cylinder diesel engine 1.6 L 03L.1
Electric interface for external use: [UF0] : Without electric interface
Hill hold control: [UG1] : Hill hold control
Instrument inserts: [U0C] : Instrument insert with tachometerclock and km/h speedometer
