TEMAT: Proszę o sprawdzenie VW Passat B6 wvwzzz3cz6e098150
Proszę o sprawdzenie VW Passat B6 wvwzzz3cz6e098150 2012/01/03 20:39 #20321
  • sowin90
  • sowin90 Avatar
Bardzo prosiłbym o jak najwięcej informacji na temat VW Passat B6 o nr VIN :
wvwzzz3cz6e098150
Dziękuje z góry i pozdrawiam.
Odp: Proszę o sprawdzenie VW Passat B6 wvwzzz3cz6e098150 2012/01/03 20:52 #20323
Dekodowanie numeru VIN WVWZZZ3CZ6E098150 Sprawdź ten VIN na autobaza.pl ▸ na www.automo.pl
Vehicle Identification No.: WVWZZZ3CZ6E098150
Model Designation: passat estate
Model: PA
Date of production: 30.09.2005
Model year: 2006
Sales type: 3C5046
Engine code: BKP
Transmission code: HQL
Axle drive: 6A
Interior trim code: AR
Roof color: 8E
Exterior color/Paint Code: 8E/A7W
"Multimedia", video/DVD/notebook connection: [9WC] : Without "Multimedia" in vehicle
Activated carbon canister: [1E0] : Without activated charcoal canister
Additional child seat anchors: [3B4] : Child seat anchor forchild seat system ISOFIX
Additional warning lights: [9TC] : Additional reflectors (door area)
Antennas: [8ZH] : Antenna for AM/FM reception, "diversity"
Anti-theft protection system: [7AR] : Electronic vehicle immobilization devicewith alarm system and backup horn
Auxiliary heating: [9M0] : Without auxiliary/parking heater
Backrest release: [3H0] : Without backrest release for front seats
Batteries: [J1D] : Battery 380 A (72 Ah)
Body measures: [5C0] : Without special body measures
Body style: [K8D] : Station Wagon Variant/Avant
Brackets: [3P1] : Bracket for first aid kit and warningtriangle
Brake type, front: [1LJ] : Disc brakes, front
Brake type, rear: [1KU] : Disc brakes, rear
Braking systems: [1AT] : Electronic stabilization program (ESP)
Breakaway interior mirror: [4L6] : Breakaway interior rear view mirror,automatically dimming
Bumper: [2JB] : Standard bumpers
CD ROM/DVD/SD card: [7QA] : Without CD/DVD for navigation
CD changer/CD player: [7A0] : Without CD changer/CD player
Cassette and CD storage unit: [4W0] : Without cassette and CD storage unit
Center console: [3D1] : Center console
Center rear seat belts: [3C7] : 3-point seat belt for center rear seat
Country codes: [FE0] : Without country code (no DVD player invehicle)
Cruise control: [8T2] : Cruise control system (CCS)electronic
Cruise control warning and speed limit system: [6Y9] : W/o cruise control speed limit system
Cup holder: [4M6] : Cup holder
Customized installation: [FC0] : Without customized installation
Door and lid locking system: [4K3] : Radio remote controlled central lockingoperated from inside and safe securing
Door and side trim panels: [3LC] : Door and side trim panel in foam filmand woven fabric
Drive layout: [1X0] : Front wheel drive
Electronic map cooling system: [QS0] : Without electronic map cooling system
Engine specifications: [D3X] : 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection systembase engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0
Equipment levels: [A8B] : Basic equipment
Exterior mirror setting: [6XN] : Exterior mirrors: electricallyadjustable, separately heated
Exterior noise suppression measures: [2B0] : Without additional exterior noisesuppression
Fire extinguisher: [6A0] : Without fire extinguisher
First aid kit / warning triangle: [1T2] : Warning triangle
Floor mats: [0TA] : Without floor mats
Front fog light/additional headlight: [8WD] : Integrated front fog light
Front license plate bracket: [6W1] : License plate bracket front (large)
Front seat, left: [3TB] : Standard seat, front left
Front seat, right: [3SB] : Standard seat, front right
Fuel systems: [0F9] : Cooled fuel system for diesel engine
Gearshift knob/handle: [6Q2] : Leather gearshift knob/handle
General operating permit, alterations: [C05] : Operating permit, alteration
Generators: [8GV] : Alternator 180 A
Headlight: [8BG] : Twin-headlight for driving on the right,with integrated high beam
Headlight activation: [8K8] : Low beam assistant with"Coming Home" function
Headlight washer system: [8X0] : Without headlight washer system
Headlight-range adjustment: [8Q1] : Headlight-range adjustment
Headphone port, rear: [8MA] : Without headphone port rear
Heat accumulator system/additional heater: [7E6] : Electric auxiliary air heater
Heated washer nozzles: [9T1] : Heated washer nozzles, front
Heating and air conditioning system: [9AK] : Climatronic with impact pressurecontrol free of cfc
Insert for the filling up of unleaded fuel/fuel type: [2G0] : Without insert for the filling up offuel
Inserts: [5MA] : Decorative inserts
Installation differentiation for vehicle components: [0ES] : Installation differentiation fortransmission DQ250vehicle components
Installation parts for engine (engine mount system): [1VG] : Installation parts for four-cylinderengine
Interior light in foot area: [6T0] : Without interior light in footwell
Left vanity mirror: [4SG] : Left vanity mirror illuminatedextractable sun visor
Lock operation for tailgate/trunk lid: [4E2] : Tailgate/trunk lid releasefrom inside (electrically)
Lockable wheel bolts: [1PA] : Standard wheel bolts
Luggage compartment floor covering: [6SM] : Needle-punched trunk floor covering(Dilours)
Lumbar support: [7P0] : Without lumbar supportin seat backrests
Mass damper for steering wheels: [1Q1] : Mass damper for steering wheel, 26.5Hz
Moldings: [4ZE] : Black moldings
Multi-function display/trip computer: [9Q5] : Multi-function display with control
Nameplate set: [1DG] : Nameplate set "TDI"
Operating voltage 12V plus 100 V inverter: [9Z3] : Operating voltage 12 V plus 230inverter
Outer rear seat belts: [3ZB] : 3-point seat belts, outer rear with ECElabel
Owner's manuals: [0VC] : Information kit in German
Paint coating: [FB0] : Standard paint coating
Paint preservative/transit coating: [5K1] : Paint preservative (wax)
Park distance control: [7X0] : Without park distance control
Partition: [3CX] : Net partition
Preparation for sound combination for rotating emergency light: [9F0] : Without sound combination for rotatingemergency light and radio antennapreparation
Protective side molding: [4B1] : Protective side molding
Radiator grille: [6KA] : Radiator grille
Radios: [8YL] : Radio with CD player
Reading light: [8S7] : Two reading lights front
Rear cargo area: [3GA] : Without cargo area
Rear license plate bracket: [6P1] : License plate bracket rear (ECE)
Rear seats: [3NE] : Rear seat bench/backrest, split foldingwith center armrest
Right exterior mirror: [5RQ] : Right exterior mirror: convex
Right vanity mirror: [4TL] : Vanity mirror, right, illuminatedextractable sun visor
Roll-up sun screen for rear and side windows: [3Y0] : Without roll-up sun screen
Roof rails/roof load rack: [3S2] : Black roof rails
Scuff plates: [7M0] : Plastic scuff plates in door apertures
Seat adjustment: [3L1] : Manual height adjustment for left frontseat
Seat belt check: [9P1] : Seat belt reminder, electriccontact in buckle
Seat covering: [N4C] : Fabric seat covering
Seat ventilation/massage seat: [4D0] : Without seat ventilation/massage seat
Second battery/battery installation: [8FA] : Without second battery
Shock absorption, chassis, front: [G07] : Front shock absorption
Shock absorption, chassis, rear: [1JA] : Rear shock absorption, basic design 1
Side air bag: [4X3] : Side air bag front with curtain air bag
Side lights: [8F2] : Side turn signal lights
Ski bag: [3X0] : Without load-through provision
Smoking/non-smoking package: [9JB] : Smoking package, ashtray front and rear
Socket: [7B5] : 12-volt socket(s)
Spare wheel/breakdown set: [1G8] : Breakdown set
Speaker installation: [8RE] : 4 speakers (passive)
Special alarm systems: [9A0] : Without taxi alarm system
Special labels/plates: [2KW] : Labels/plates in German, French, andDutch
Steering: [1N3] : Speed-related variable steering assist(Servotronic)
Steering wheels: [1MA] : Steering wheel
TV reception/digital radio reception: [QV0] : W/o TV reception/digital radio reception
Taillight assemblies: [8SK] : Taillight assemblies with diodes (LED)
Telephone/telematics: [9W8] : Car phone preparation
Tie down straps/net/pocket: [6M0] : Without tie down straps/net/pocket
Tire pressure warning light: [7K0] : Without tire pressure warning light
Tires: [HJ6] : Tires 205/55 R16 94V xl
Tool kit and jack: [1S1] : Tool kit and jack
Transit coating: [NT0] : Transit coating (type 1)
Transmission specifications: [G1A] : 6-speed automatic transmission
Transmission types/gearshift mechanisms: [0G7] : Tiptronic
Trunk sill protection: [2P1] : Plastic trunk sill protection
Type approval countries/countries with special requirements: [B01] : Type approval Germany
Umbrella: [NS0] : Without umbrella(s)
Vehicle class differentiation units/platform components: [0HG] : Vehicle class differentiation 3C0
Weight category front axle: [L03] : Suspension range 03installation control only, norequirement forecast
Weight category rear axle: [0YD] : Weight range 4installation control only, norequirement forecast
Wheel covers: [1NH] : Full wheel covers
Wheels: [C1G] : Steel wheels 6.5J x 16
Window regulator: [4R5] : Power windows with comfort operation andcircuit breaker, mechanical windowregulators rear
Windshield glass type: [4GF] : Windshield in heat-insulating glass
Windshield wiper intermittent control: [8N3] : Windshield wiper intermittent controlwith rain sensor
Audio-response system/voice control: [QH0] : Without voice control
Child seats: [QA0] : Without child seat
Compass/traffic sign display: [QR0] : Without compass/traffic sign display/traffic signs recognition
Service interval prolongation: [QG1] : Service interval prolongation
Tray areas package: [QE0] : Without tray areas package/box
Base engine: [TB3] : 4-cylinder diesel engine 2.0 Lunit 03G.B
Control number (no PR-Family): [SX8] : Model year change calendar week 22
Instrument inserts: [U5A] : Instrument insert, km/h speedometer
Parking brake: [UH2] : Parking brake
Pedestrian protection: [VL1] : Extended pedestrian protection measures
Remote-controlled garage door opener: [VC0] : W/o remote-controlled garage door opener
