TEMAT: Skoda Octavia 1.6 2004 TMBDX21U242867405
Skoda Octavia 1.6 2004 TMBDX21U242867405 2013/06/04 11:26 #44588
  • luckd
  • luckd Avatar
Proszę o rozkodowanie VIN i sprawdzenie przebiegu.
otomoto.pl/skoda-octavia-1-6b-102km-bezwypadek-C29394604.html
TMBDX21U242867405 Sprawdź ten VIN na autobaza.pl ▸
Ostatni wpis w książce 2010r. 120tys. km.
Skoda Octavia 1.6 2004 TMBDX21U242867405 2013/06/06 10:57 #44712
TMBDX21U242867405
TMBDX21U242867405
Skoda
Octavia Octavia 1.6 I Classic
1.60 [75kW] [102HP] [4cyl.]
Vehicle Identification No.:
Data are estimates for TMBDX21U242867405
Model Designation:
SKODA OCTAVIA OCTAVIA 1.6 I CLASSIC
OCTAVIA
Date of production:
10.2003
Model year:
2004
Engine code:
BFQ
0:
Drive
1:
3-point seat belts with tensioner and height adjustment, front
2:
3-point seat belts, outer rear with ECE label
3:
4 doors
4:
4 speakers (passive)
5:
4-cylinder gasoline engine 1.6 L unit 06A.S (aluminum)
6:
4-cylinder gasoline engine 1.6 L/75 kW with multi-point injection base engine is T0B/T53/TC3/TL2
7:
5-speed manual transmission
8:
Activated carbon canister
9:
Additional exterior noise suppression
10:
Additional reflectors (door area)
11:
Air duct, standard
12:
Alternator 90A
13:
Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
14:
Antifreeze up to -25 degree celsius tolerance up to -30 degree C
15:
Articulated and height-adjustable headrests for front seats
16:
Axial and vertical adjustable steering column
17:
Basic equipment
18:
Battery 220 A (44 Ah)
19:
Body-colored exterior mirror housings
20:
Brake pad wear indicator
21:
Carrier frequency 433.92 MHz-434.42 Mhz
22:
Center high-mounted stop light
23:
Comfort sports seats, front
24:
Component parts set, complying with vehicle type for Germany, various parts
25:
Display and warning tone f. opened doors
26:
Driver s and front passenger air bag with front passenger air bag deactivation
27:
Drum brakes, rear
28:
Electric throttle actuation
29:
Electronic map cooling system
30:
Electronic vehicle immobilization device
31:
Emission standard EU4
32:
Exterior mirrors electrically adjustable/heated
33:
Fabric seat covering
34:
Filler neck module 2 with insert
35:
Foldable trunk cover
36:
Fresh air intake system with activated charcoal canister
37:
Front disc brakes with integrated adapter
38:
Front shock absorption
39:
Front stabilizer
40:
Front wheel drive
41:
Fuel filler cap
42:
Fuel system for carburetor gasoline engine
43:
Fuel tank with special material treatment
44:
Full wheel covers
45:
Gearshift linkage
46:
Glove compartment door with light
47:
Halogen headlight for driving on the right
48:
Hatchback
49:
Headlight-range adjustment
50:
Increase in initial standard fuel filling
51:
Information kit in German
52:
Installation differentiation for transmission MQ170 vehicle components
53:
Instrument insert with km/h speedometer,clock, tachometer and trip odometer
54:
Integrated front fog light
55:
Key for locking system with remote control
56:
Labels/plates in German and French
57:
Leatherette gearshift boot
58:
Left exterior mirror aspherical, electrically adjustable and heated
59:
Left vanity mirror with cover
60:
Left-hand drive vehicle
61:
License plate bracket front (large)
62:
License plate bracket rear (ECE)
63:
Luggage nets/pockets on backrests
64:
Manual height adjustment for left front seat
65:
Manually adjustable lumbar support in front seats
66:
Manually controlled air conditioning
67:
Multi-function display/on-board computer
68:
Nameplate set in base trim
69:
No special purpose vehicle, standard equipment
70:
Non-dipping breakaway inside rear view mirror
71:
Not hot country
72:
Operating permit, initial registration
73:
Padded dashboard
74:
Paint preservative (wax)
75:
Plastic gearshift knob/handle
76:
Plastic hand brake lever handle
77:
Platform group class 2
78:
Power steering
79:
Power windows with comfort operation andcircuit breaker, mechanical window regulators rear
80:
Preparation for roof load rack
81:
Protective side molding
82:
Radiator grille
83:
Radio HIGH
84:
Radio remote controlled central locking operated from inside and safe securing
85:
Rear floor panel module, type 3
86:
Rear fog light for driving on the right
87:
Rear headrests
88:
Rear seat bench/backrest, split folding
89:
Rear shock absorption, basic design 2
90:
Rear stabilizer
91:
Rear window wiper and washer system with intermittent control
92:
Right exterior mirror convex, electrically adjustable and heated
93:
Right vanity mirror with cover
94:
Roof antenna
95:
Service interval prolongation
96:
Side air bag front
97:
Side and rear windows in heat-insulatingglass
98:
Side turn signal lights
99:
Single-tone horn
100:
Special identification plate for EC for M1 passenger vehicle
101:
Standard bumpers
102:
Standard design
103:
Standard manufacturing sequence
104:
Standard rear axle
105:
Standard wheel bolts
106:
Static lap belt, center rear
107:
Steel spare wheel with original equipment tires
108:
Steel wheels 6J x 15 Offset 38
109:
Steering wheel for air bag system
110:
Suspension range 17 installation control only, no requirement forecast
111:
Tailgate/trunk lid unlocking from outside
112:
Taillight assemblies, standard design
113:
Tires 195/65 R15 V
114:
Tufted trunk floor covering
115:
Two reading lights front
116:
Type approval Germany
117:
Vehicle class differentiation 1U0
118:
Vehicle with standard production scope
119:
Windshield in heat-insulating glass
120:
Windshield wiper intermittent control with potentiometer (four speeds)
