TEMAT: VW PASSAT WVWZZZ3BZ2P446952 UWAGA ANGOL!
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 04:40 #50755
  • grubynowy1
  • grubynowy1 Avatar
Witam chciałbym sie dowiedziec cos po tym vinie co da sie sprawdzic
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:14 #50779
Przegladnij tematy inne i bedzie widac co brakuje twojemu
Konkretnie brak linku. Podaj go to ci pokaze cos interesujacego baaardzo :whistle:
Ostatnio zmieniany: 2013/10/18 07:15 przez Inspektor.
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:27 #50782
  • grubynowy1
  • grubynowy1 Avatar
ogłoszenie jest w prasie lokalnej a smaochód ma moj znajomy
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:37 #50786
I co ci znajomy o nim mowil ciekawego? jaki ma przebieg?
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:38 #50787
  • grubynowy1
  • grubynowy1 Avatar
200 tys przeszlo
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:43 #50789
  • grubynowy1
  • grubynowy1 Avatar
a co jest tam takiego ciekawego
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:45 #50790
A w jakim miescie do sprzedania?
WVWZZZ3BZ2P446952 Sprawdź ten VIN na autobaza.pl ▸
WVWZZZ3BZ2P446952
Germany
Mozel
VOLKSWAGEN
Passat
Wersja:
B5
2.00 [85kW] [115HP] [4cyl.]
Vehicle Identification No.:
Data are estimates for WVWZZZ3BZ2P446952
passat saloon PA
Date of production:
04.2002
Engine code:
AZM
0:
12-volt socket in luggage boot
1:
2002
2:
3-point seat belts with tensioner and height adjustment, front
3:
4-cylinder gasoline engine 2.0 L unit 06B.J
4:
4-cylinder gasoline engine 2.0 L/85 kW base engine is T04/T10/T11/T51
5:
5-speed manual transmission
6:
8 speakers (passive)
7:
Activated carbon canister
8:
Additional exterior noise suppression
9:
Additional stone guard body covers
10:
Air bag for driver and front seat passenger
11:
Alloy wheels 8.5J x 19
12:
Alternator 90A
13:
Antifreeze up to -25 degree celsius tolerance up to -30 degree C
14:
Articulated and height-adjustable headrests for front seats
15:
Battery 280 A (60 Ah)
16:
Black moldings
17:
Carrier frequency 433.92 MHz-434.42 Mhz
18:
Center high-mounted stop light
19:
Child seat anchor for child seat system ISOFIX
20:
Climatronic, free of cfc
21:
Component parts set, complying with vehicle type for Great Britain, various parts
22:
Cup holder
23:
Decorative inserts
24:
Dipping breakaway interior rear view mirror
25:
Disc brakes, front (Geomet D)
26:
Disc brakes, rear
27:
Door and side trim panel in foam film and woven fabric
28:
Electric throttle actuation
29:
Electronic stabilization program (ESP)
30:
Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
31:
Emission standard EU4
32:
Exterior mirrors electrically adjustable, separately heated
33:
Front wheel drive
34:
Full wheel covers
35:
Gearshift lever
36:
Headlight-range adjustment
37:
Ibolours floor covering
38:
Increase in initial standard fuel filling
39:
Insert for the filling up of unleaded fuel
40:
Installation differentiation for build status of vehicle class B5 (VW Passat)
41:
Installation parts for four-cylinder engine
42:
Instrument insert with tachometer clock and mph speedometer
43:
Labels/plates in English
44:
Lap belt with retractor for the center rear seat
45:
Leatherette gearshift boot
46:
Left exterior mirror convex
47:
Left vanity mirror, illuminated
48:
License plate carrier front (large)
49:
Local interference suppression for FM/AM radio reception
50:
Lockable glove compartment door
51:
52:
Mosel manufacturing sequence
53:
Multi-function display/on-board computer
54:
Nameplate set 2.0
55:
No flame retardent materials
56:
No special edition
57:
No special purpose vehicle, standard equipment
58:
Not hot country
59:
Notchback
60:
Operating permit, alteration
61:
Outdoor temperature gage
62:
Plastic gearshift knob/handle
63:
Plastic hand brake lever handle
64:
Power steering
65:
Power windows with comfort operation
66:
Protective side molding
67:
Radio gamma
68:
Radio remote controlled central locking operated from inside and safe securing
69:
Rear floor panel module, type 2
70:
Rear fog light for driving on the left
71:
Rear headrests
72:
Rear seat bench unsplit, backrest split folding
73:
Right exterior mirror aspherical
74:
Right vanity mirror illuminated
75:
Right-hand drive vehicle
76:
Roof antenna
77:
Service interval prolongation
78:
Side air bag front
79:
Side and rear windows in heat-insulating glass
80:
Side turn signal lights
81:
Smoking package, ashtray front and rear
82:
Special identification plate for EC for M1 passenger vehicle
83:
Special plates/stickers/ safety certificates for England
84:
Standard bumpers
85:
Standard climatic zones
86:
Standard equipment
87:
Standard front seats
88:
Standard suspension/shock absorption
89:
Standard wheel bolts
90:
Steel spare wheel with original equipment tires
91:
Steering wheel for air bag system
92:
Surface, interior trim, soft-touch paint
93:
Taillight assemblies, standard design
94:
Tires 195/65 R15 V
95:
96:
Transmission shafts w/ 108 mm in diameter
97:
Tufted trunk floor covering (dimensionally stable)
98:
Twin headlight for driving on the left, with integrated high beam
99:
Two reading lights front, two rear
100:
Type approval Great Britain and Northern Ireland
101:
W/o TV reception/digital radio reception
102:
W/o car phone preparation/installation
103:
W/o catalytic converter warning light
104:
W/o heat accumulator/auxiliary heating
105:
W/o remote-controlled garage door opener
106:
Warning triangle
107:
Weight category front axle weight range 6
108:
Weight range 4 installation control only, no requirement forecast
109:
Windshield in heat-insulating glass with sunshield
110:
Windshield wiper intermittent control with potentiometer (four speeds)
111:
Without CD changer/CD player
112:
Without CD/DVD for navigation
113:
114:
Without additional lower part for luggage compartment floor
115:
Without additional malfunction display
116:
Without additional seals outside
117:
Without additional tires
118:
Without alternative drive module
119:
Without aluminum/chrome work package
120:
Without automatic transmission indicator light
121:
Without auxiliary/parking heater
122:
Without cassette and CD storage unit
123:
Without center armrest front
124:
Without child seat
125:
Without controls
126:
Without cruise control system (CCS)
127:
Without cruise control warning system
128:
Without duty-free and cost-free tires
129:
Without fire extinguisher
130:
Without floor mats
131:
Without front fog light
132:
Without hands-free system
133:
Without headlight washer system
134:
Without heated washer nozzles
135:
Without information kit
136:
Without load-through provision
137:
Without luggage nets/pockets on backrests
138:
Without lumbar support in seat backrests
139:
Without mass damper for steering wheel
140:
Without navigation device
141:
Without park distance control
142:
Without parking light warning light
143:
Without partition
144:
Without preparation for two-way radio installation
145:
Without roll-up sun screen
146:
Without roof insert (standard roof)
147:
Without roof rails/roof load rack
148:
Without seat belt reminder
149:
Without seat heater
150:
Without sound combination for rotating emergency light and radio antenna preparation
151:
Without special body measures
152:
Without special headlight activation
153:
Without stickers and badges
154:
Without supertone system and tone sequence control
155:
Without surface protection, with additional transit coating
156:
Without taxi alarm system
157:
Without tire pressure warning light
158:
Without trailer hitch
159:
Without transmission shafts f. rear axle
160:
Woven fabric seat covering
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:48 #50791
  • grubynowy1
  • grubynowy1 Avatar
cena jest atrakcyjna bo wczesniej mial przekladke tylko ciekawi mnie czy samochod nie jest po wypadku
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:50 #50792
  • grubynowy1
  • grubynowy1 Avatar
chociaz czasami lepszy moze angol niz wypadkowy niemiec czy holender sam nie wiem
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:51 #50793
  • grubynowy1
  • grubynowy1 Avatar
WVWZZZ3BZ2P446952
WVWZZZ3BZ2P446952
Germany
Mozel
VOLKSWAGEN
Passat
Wersja:
B5
passat saloon PA
Date of production:
04.2002
Engine code:
AZM
0:
1:
2002
2:
3:
4:
5:
6:
7:
8:
9:
10:
11:
12:
Alternator 90A
13:
14:
15:
16:
Black moldings
17:
18:
19:
20:
21:
22:
Cup holder
23:
Decorative inserts
24:
25:
26:
Disc brakes, rear
27:
28:
29:
30:
31:
32:
33:
Front wheel drive
34:
Full wheel covers
35:
Gearshift lever
36:
37:
38:
39:
40:
41:
42:
43:
44:
45:
46:
47:
48:
49:
50:
51:
52:
53:
54:
Nameplate set 2.0
55:
56:
No special edition
57:
58:
Not hot country
59:
Notchback
60:
61:
62:
63:
64:
Power steering
65:
66:
67:
Radio gamma
68:
69:
70:
71:
Rear headrests
72:
73:
74:
75:
76:
Roof antenna
77:
78:
Side air bag front
79:
80:
81:
82:
83:
84:
Standard bumpers
85:
86:
Standard equipment
87:
88:
89:
90:
91:
92:
93:
94:
Tires 195/65 R15 V
95:
96:
97:
98:
99:
100:
101:
102:
103:
104:
105:
106:
Warning triangle
107:
108:
109:
110:
111:
112:
113:
114:
115:
116:
117:
118:
119:
120:
121:
122:
123:
124:
Without child seat
125:
Without controls
126:
127:
128:
129:
130:
Without floor mats
131:
132:
133:
134:
135:
136:
137:
138:
139:
140:
141:
142:
143:
Without partition
144:
145:
146:
147:
148:
149:
Without seat heater
150:
151:
152:
153:
154:
155:
156:
157:
158:
159:
160:
a mozesz mi odpowiedziec czy samochod jest po wypadku jakims
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 07:58 #50795
  • grubynowy1
  • grubynowy1 Avatar
chodzi mi glownie o to by miec pewnosc czy samochod bedac w Anglii nie byl po wypadku da sie to gdzies sprawdzic
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 08:32 #50800
Niestety nie. Tylko miernik
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 08:38 #50802
  • grubynowy1
  • grubynowy1 Avatar
dzieki za info sprawdze i moze zastanowie sie nad zakupem
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 08:39 #50803
  • grubynowy1
  • grubynowy1 Avatar
TEMAT ZAMYKAM
VW PASSAT WVWZZZ3BZ2P446952 2013/10/18 09:00 #50809
Angola ja bym nie wzial. Pozniej sprzedac ciezko i ryzyko jak zataisz a poza tym moze byc wieczny problem z czyms bo przekladki zazwyczaj po taniosci sa robione
