TEMAT: Proszę o sprawdzenie ibizy
Proszę o sprawdzenie ibizy 2013/01/06 13:30 #36158
  • blazer
  • blazer Avatar
Proszę o sprawdzenie ibizy:
VIN: VSSZZZ6LZ3R136332 Sprawdź ten VIN na autobaza.pl ▸.
Z góry dziękuje.
Odp: Proszę o sprawdzenie ibizy 2013/01/06 14:24 #36161
  • Budyń
  • Budyń Avatar
Numer VIN - VSSZZZ6LZ3R136332
Region - Spain
Fabryka / Producent - Martorell
Marka - Seat
Model - Ibiza Sport\nRok - 2002
Silnik - 1.90 [96kW] [131HP] [4cyl.]
Numer seryjny - 136332
Vehicle identification no. - Vsszzz6lz3r136332
Model designation - Ibiza sport
Date of production - 11.12.2002
Model year - 2003
Sales type - 6l1536
Engine code - ASZ
Transmission code - FJW
Axle drive - 6S
Interior trim code - DY
Roof color - Z4
Exterior color / paint code - Z4 / c9z
Activated carbon canister - Without activated charcoal canister
Additional body covers, side - Without additional side body covers (stone guard)
Additional child seat anchors - Without additional child seat anchor
Additional dust seals - Without additional seals outside
Additional instruments - Additional instruments (voltage and oil pressure)
Additional tires (winter tires) - Without additional tires
Additional warning lights - Without additional warning lights
Air bag - Driver s and front passenger air bag with front passenger air bag deactivation
Air cleaner (engine) - Standard air cleaner
Air duct, front area - Air duct, type 1
Antennas - Roof antenna
Anti-theft protection system - Electronic vehicle immobilization device
Antifreeze - Antifreeze up to -25 degree celsius tolerance up to -30 degree c
Automatic transmission indicator light - Without automatic transmission indicator light
Backrest release - Backrest release for front seat(s)
Base engine - 4-cylinder diesel engine 1.9 l unit 038.k
Batteries - Battery 340 a (70 ah)
Body measures - Additional body measures
Body style - Hatchback
Body treatment - Special body treatment
Brackets - Bracket for first aid kit and warning triangle
Brake pad wear indicator - Without brake pad wear indicator
Brake type, front - Disc brakes, front
Brake type, rear - Disc brakes, rear
Braking systems - Electronic stabilization program (esp)
Breakaway interior mirror - Dipping breakaway interior rear view mirror
Bumper - Body-colored bumpers
Cd rom/dvd/sd card - Without cd/dvd for navigation
Cd changer/cd player - Without cd changer/cd player
Carrier frequency for radio remote control - Carrier frequency 433.92 mhz-434.42 mhz
Cd enhancing underbody panel - Without cd enhancing underbody panel
Center high-mounted stop light - Center high-mounted stop light
Center rear seat belts - Static lap belt, center rear
Center sun visor - Without center sun visor
Chrome work package - Without aluminum/chrome work package
Climatic zones - Standard climatic zones
Component part sets with country-specific design requirements - Component parts set, complying with vehicle type for germany, various parts
Components with special surface appearance - Components without special surface appearance
Cruise control - Cruise control system (ccs) electronic
Cruise control warning and speed limit system - Without cruise control warning system
Cup holder - Without cup holder
Dashboard - Dashboard with deleted option
Door and lid locking system - Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels - Door and side trim panel
Doors - 2 doors
Drawers under front seats - Without drawers under front seats
Electronic map cooling system - Without electronic map cooling system
Emission standard - Emission standard eu3
Engine cover - Engine cover
Engine specifications - 4-cyl. turbo diesel engine 1.9 l/96 kw tdi with pump-jet injection system base engine is t9j
Equipment levels - Sports equipment
Exhaust tailpipe - Rear exhaust tailpipe (standard)
Exterior mirror setting - Exterior mirrors electrically foldable and electrically adjustable/heated
Exterior noise suppression measures - Additional exterior noise suppression
Fire extinguisher - Without fire extinguisher
First aid kit / warning triangle - Without first aid kit and warning triangle
Floor mats - Without floor mats
Foot area lining - Foot area lining with cover
Frame forestructure - Long frame forestructure
Fresh air intake for passenger compartment (with particulate filter) - Dust and pollen filter
Front fog light/additional headlight - Integrated front fog light
Front license plate carrier - Without license plate carrier front
Front stabilizer - Front stabilizer
Front underbody guard - Without additional front underbody guard
Fuel filler cap/door, locking option - Fuel filler cap
Fuel quantity for initial filling - Initial standard fuel filling
Fuel systems - Cooled fuel system for diesel engine
Fuel tank treatment - Fuel tank with special material treatment
Gearshift boot/cover - Leatherette gearshift boot
Gearshift knob/handle - Leather gearshift knob/handle
General operating permit, alterations - Operating permit, alteration
Generators - Alternator 120 a
Glove compartment - Glove compartment door without light
Grab handles at roof frame - Folding grab handles
Hand brake lever handle - Leather hand brake lever handle
Headlight - Headlight with gas discharge lamp and turn signal light for driving on the right
Headlight activation - Without special headlight activation
Headlight washer system - Headlight washer system
Headlight-range adjustment - Automatic headlight-range adjustment static
Headrests - Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater - Electric auxiliary air heater
Heated rear window - Heated rear window
Heated washer nozzles - Heated washer nozzles, front
Heating and air conditioning system - Climatic air-conditioning system (semi-automatic)
Horns - High-sounding horn
Identification plates - Special identification plate for ec for m1 passenger vehicle
Ignition/starter switch locking system - Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type - Filler neck module 1 without insert
Inserts - Without decorative inserts
Installation differentiation for vehicle components - Installation differentiation for transmission mq 350 vehicle components
Instrument inserts - Instrument insert with tachometer clock and km/h speedometer
Interior light in driver compartment - Interior light with switch-off delay and door pillar switch
Key for locking system - Key for locking system with remote control
Left exterior mirror - Left exterior mirror aspherical
Left vanity mirror - Without left vanity mirror, but pocket in sun visor
Light package (lighting) - Without add. lights (interior lighting)
Lock operation for tailgate/trunk lid - Tailgate/trunk lid unlocking from outside
Lockable wheel bolts - Wheel bolts with anti-theft protection (unlockable)
Luggage compartment cover - Foldable trunk cover
Luggage compartment floor covering - Tufted trunk floor covering
Luggage compartment lighting - Luggage compartment lighting
Luggage compartment lining - Full fleece trunk lining
Luggage net/pocket on backrest(s) - Luggage net on backrest, right seat
Manufacturing sequence differentiation - Standard manufacturing sequence
Mass damper for steering wheels - Without mass damper for steering wheel
Molding roof liner - Unsplit molding roof liner
Multi-function display/trip computer - Multi-function display/on-board computer
Nameplate set - Nameplate set tdi
Navigation device - Without navigation device
Outer rear seat belts - 3-point seat belts, outer rear with ece label
Owner s manuals - Information kit in german
Paint preservative/transit coating - Without surface protection, with additional transit coating
Partition - Without partition
Pillar lining - Exterior pillar lining
Platform group class - Platform group class 2
Platform module floor pan, rear - Rear floor panel module, type 3
Protective side molding - Protective side molding
Radiator grille - Radiator grille
Radios - Radio for comfort-class vehicle
Reading light - Without reading light
Rear axle - Heavy-duty rear axle (design 2)
Rear fog light - Rear fog light for driving on the right
Rear headrests - Rear headrests
Rear license plate carrier - Without license plate carrier rear
Rear seat catch - Rear seat catch
Rear seats - Rear seat bench/backrest, split folding
Rear window wiper and washer system - Rear window wiper and washer system with intermittent control
Restraint systems, front - 3-point seat belts with electric tensioner and height adjustment, front
Right exterior mirror - Right exterior mirror convex
Right vanity mirror - Right vanity mirror with cover
Roof insert/convertible top - Without roof insert (standard roof)
Roof rails/roof load rack - Without roof rails/roof load rack
Seat adjustment - Manual height adjustment for left front seat
Seat belt check - Without seat belt reminder
Seat covering - Fabric seat covering
Seat heater - Seat heater for front seats separately controlled
Service interval prolongation - Without service interval prolongation
Shock absorption, chassis, front - Front shock absorption
Shock absorption, chassis, rear - Rear sports shock absorption
Side air bag - Side air bag front
Side and rear windows - Side and rear windows in heat-insulating glass
Side lights - Side turn signal lights (white)
Smoking/non-smoking package - Smoking package, ashtray front
Socket - Without socket
Spare wheel/breakdown set - Steel spare wheel with original equipment tires
Speaker installation - 8 speakers (passive)
Special editions - No special edition
Special labels/plates - Labels/plates in german
Speedometer cable and seal - Speedometer sensor without seal (electronic speedometer sensor)
Steering - Power steering
Steering column systems - Axial and vertical adjustable steering column
Steering system arrangement - Left-hand drive vehicle
Steering wheels - Leather steering wheel
Sticker (customized or special edition) - Without stickers and badges
Taillight assemblies - Taillight assemblies, standard design
Telephone/telematics - without car phone preparation/installation
Tire suppliers - Tires with o specification of tire brand
Tires - Tires 205/45 r16 83w
Tool kit and jack - Tool kit and aluminum jack
Trailer hitch - Without trailer hitch
Transmission specifications - 6-speed manual transmission
Transmission types/gearshift mechanisms - Cable gearshift
Trunk sill protection - Plastic trunk sill protection
Type approval countries/countries with special requirements - Type approval germany
Vehicle class differentiation units/platform components - Vehicle class differentiation 6l0
Vehicle specifications - No special purpose vehicle, standard equipment
Vehicle type - Vehicle with standard production scope
Washer fluid level indicator - Without washer fluid level indicator
Weight category front axle - Suspension range 43 installation control only, no requirement forecast
Weight category rear axle - Weight range 1 installation control only, no requirement forecast
Wheel covers - Covers for alloy wheels
Wheel housing liners - Wheel housing liner front and rear
Wheels - Alloy wheels 6.5j x 16
Window regulator - Power windows
Windshield glass type - Windshield in heat-insulating glass
Windshield wiper arms/blades - Windshield wiper arms/blades with additional guide vanes
Windshield wiper intermittent control/ light/rain sensor - Windshield wiper intermittent control with potentiometer (four speeds)
Child seats - Without child seat
Front seats - Comfort sports seats, front
Country-specific product program - National sales program germany
Odp: Proszę o sprawdzenie ibizy 2013/01/07 06:32 #36208
blazer zapoznales sie z regulaminem dzialu ocena auta?
Odp: Proszę o sprawdzenie ibizy 2013/01/07 09:41 #36216
  • kprzemo24
  • kprzemo24 Avatar
Brak historii
Data produkcji: 2002-12-11
