witam.
prosiłbym o info przebiegu albo jakieś zdjęcia odnośnie tego auta. vin: VSSZZZ6LZ2R008872 Sprawdź ten VIN na autobaza.pl ▸ |
2007-01-05 123891km
Dekodowanie numeru VIN VSSZZZ6LZ2R008872 na www.automo.pl
Nazwa dekodera: Dekoder VIN dla Grupy VAG #2 Vehicle Identification No.: VSSZZZ6LZ2R008872 Date of production: 29.01.2002 Model year: 2002 Sales type: 6L1324 Engine code: ATD Engine parameters: 4-cylinder, 74 kW (100 p.s.), 1.9 l Transmission code: EWT Interior trim code: CY Roof color: H2 Exterior color / paint code: H2 / S7U 1E0: Without activated charcoal canister 6EA: Without additional side body covers (stone guard) 3B0: Without additional child seat anchor 6U0: Without additional seals outside 8LA: Without additional instruments/switches 2WA: Without additional tires 9TA: Without additional warning lights 4UF: Driver`s and front passenger air bag with front passenger air bag deactivation 1L0: Standard air cleaner VK1: Air duct, type 1 8L3: Roof antenna 7AA: Electronic vehicle immobilization device 1C1: Antifreeze up to -25 degree celsius tolerance up to -30 degree C 9FA: Without automatic transmission indicator light 5B0: Backrest release for left front seat right front seat w/ "Easy Entry" funct. T5X: 4-cylinder diesel engine 1.9 L unit 038.L J0L: Battery 340 A (70 Ah) 5C7: Additional body measures K8G: Hatchback 6J1: Special body treatment 3P0: Without bracket for first aid kit and warning triangle 9U0: Without brake pad wear indicator 1LQ: Front disc brakes with integrated adapter 1KD: Disc brakes, rear 1AP: Anti-spin regulation (ASR) with electronic differential lock (EDL), lightweight design 4L2: Dipping breakaway interior rear view mirror 2JG: Body-colored bumpers 7QA: Without CD/DVD for navigation 7A0: Without CD changer/CD player 5D1: Carrier frequency 433.92 MHz-434.42 Mhz 8R1: Center high-mounted stop light 3C1: Static lap belt, center rear GA0: Without center sun visor QA0: Without child seat QJ0: Without aluminum/chrome work package 0Y1: Standard climatic zones B0A: Component parts set without country-specific design requirement 6FF: Body-colored exterior mirror housings and various add-on parts S0C: Introductory volume 8T0: Without cruise control system (CCS) 6Y0: Without cruise control warning system 4M5: Cup holder 4N2: Standard dashboard 4K3: Radio remote controlled central locking operated from inside and safe securing 3LD: Door and side trim panel 0A1: 2 doors QN2: Drawer under right front seat 1X0: Front wheel drive QS0: Without electronic map cooling system 0GE: Emission standard EU3 MS7: 4-cyl. turbo diesel eng. 1.9 L/74 kW TDIpump-jet injection system Base engine is T5X/T21/T71 A8D: Luxury equipment 0P0: Rear exhaust tailpipe (standard) 6XE: Exterior mirrors: electrically foldable and electrically adjustable/heated 2B3: Additional exterior noise suppression (hood, capsule and dash panel) 6A0: Without fire extinguisher 1T0: Without first aid kit and warning triangle 0TA: Without floor mats QM1: Foot area lining with cover AC1: Long frame forestructure 2V1: Dust and pollen filter 8WD: Integrated front fog light 6W0: Without license plate bracket front 0AQ: Front stabilizer 1SA: Without additional engine guard 2W0: Fuel filler cap 1Z0: Initial standard fuel filling 0F9: Cooled fuel system for diesel engine 2LB: Fuel tank with special material treatment 6R1: Leatherette gearshift boot 6Q4: Comfort gearshift knob/handle C02: Operating permit, alteration 8GL: Alternator 120 A 4Z5: Glove compartment door with light 5N3: Folding grab handles 6PA: Plastic hand brake lever handle 8BG: Twin-headlight for driving on the right,with integrated high beam 8K0: Without special headlight activation 8X0: Without headlight washer system 8Q1: Headlight-range adjustment 3J7: Articulated and height-adjustable headrests for front seats 7E0: W/o heat accumulator/auxiliary heating 9X0: Without heated door lock cylinder 8P1: Heated rear window 9T0: Without heated washer nozzles 9AK: Climatronic with impact pressure control free of cfc 8Y4: High-sounding horn 1EX: Special identification plate for EC for M1 passenger vehicle 0RA: Without ignition/starter switch locking system 2G5: Filler neck module 1 without insert 5TC: Without decorative inserts 0EJ: Installation differentiation for transmission MQ 250 vehicle components U0C: Instrument insert with tachometer clock and km/h speedometer 9GB: Interior light with switch-off delay anddoor pillar switch 8QE: Key for locking system with remote control 5SL: Left exterior mirror: aspherical 4SK: Left vanity mirror not illuminated with cover and pocket QQ0: Without add. lights (interior lighting) 4E0: Tailgate/trunk lid unlocking from outside 1PA: Standard wheel bolts 3U1: Foldable trunk cover 6SC: Tufted trunk floor covering 9E1: Luggage compartment lighting 5A6: Full fleece trunk lining 4U3: Luggage net on backrest, right seat 1Q0: Without mass damper for steering wheel 6NA: Unsplit molding roof liner 9Q1: Multi-function display/on-board computer 2VP: Nameplate set "TDI" "I" 7Q0: Without navigation device 3ZB: 3-point seat belts, outer rear with ECE label 0VB: Information kit in French 5K0: Without surface protection, with additional transit coating 7X0: Without park distance control 3CA: Without partition 4XC: Exterior pillar lining 7PB: Platform group class 2 4P2: Rear floor panel module, type 3 4B1: Protective side molding 6KD: Radiator grille 8YE: Radio for comfort-class vehicle 8S1: Reading light front 0N7: Heavy-duty rear axle (design 2) 8TC: Rear fog light for driving on the right 3Q1: Rear headrests 6P0: Without license plate bracket rear 3NC: Rear seat bench/backrest, split folding 8M1: Rear window wiper and washer system with intermittent control 4QV: 3-point seat belts with electric tensioner and height adjustment, front 5RQ: Right exterior mirror: convex 4TC: Right vanity mirror with cover 3FA: Without roof insert (standard roof) 3S0: Without roof rails/roof load rack 3L3: Manual height adjustment for front seats 9P0: Without seat belt reminder N0H: Woven fabric seat covering 4A0: Without seat heater QG0: Without service interval prolongation G17: Front shock absorption 1JJ: Rear shock absorption, basic design 4X1: Side air bag front 4KX: Side and rear windows tinted green hinged quarter window operated manually 7R3: Side turn signal lights (white) 9JD: Smoking package, ashtray front 7B0: Without socket 1G2: Steel spare wheel with original equipment tires 8RM: 8 speakers (passive) E0A: No special edition 0SG: Labels/plates in French 8CC: Speedometer sensor without seal (electronic speedometer sensor) 1N1: Power steering 2C5: Axial and vertical adjustable steering column L0L: Left-hand drive vehicle 1MP: Steering wheel for air bag system 0KA: Without stickers and badges 8SA: Taillight assemblies, standard design 9W0: W/o car phone preparation/installation V0A: Tires w/o specification of tire brand HA9: Tires 195/55 R 15 85V 1S7: Tool kit and aluminum jack 1D0: Without trailer hitch G0C: 5-speed manual transmission 0G4: Cable gearshift 2P1: Plastic trunk sill protection B08: Type approval France 0CY: Vehicle class differentiation 6L0 F0A: No special purpose vehicle, standard equipment AZ0: Vehicle with standard production scope 8W0: Without washer fluid level indicator L39: Suspension range 39 installation control only, no requirement forecast 0YA: Weight range 1 installation control only, no requirement forecast 1NL: Covers for alloy wheels C0F: Alloy wheels 6J x 15 4R1: Power windows 4GF: Windshield in heat-insulating glass 9PB: Windshield wiper arms/blades with additional guide vanes 8N4: Windshield wiper intermittent control with potentiometer (four speeds) Q1A: Standard front seats Dekodowanie pochodzi z www.automo.pl |
