| DW10ATED TURBO DIESEL |
DIESEL FILTER WATER DETECTOR:
| DIESEL FUEL |
| EEC 2000 DEPOLL (ENGINE) |
SPEED SENSOR SIGNAL:
| WITHOUT SPEED SENSOR |
| EW/DW |
CATALYTIC CONVERTER:
| 3 PARTS CATALYST |
| MNTG EXCHANGER ON ENG & G/BOX |
FUEL SUPPLY CUTOFF:
| NO FUEL FEED CUT-OFF |
| WITHOUT "EOBD" AUTO-DIAGNOSTIC |
DEVICE (ANTIPOLLUTION):
| "EGR" EXHAUST GAS RECYCLING |
| L4 VEHICLE TECHNICAL DEPOLLUTION |
| WITHOUT PARTICLE FILTER |
| 1 FAN 450W WITH BLADE |
FUEL VAPOUR RETRIEVAL:
| WITHOUT PETROL VAPOUR RECUPERATION |
| MOUNTING BOSCH |
| Auto gearbox AL4 |
| Auto gearbox AL4 |
| CP 25 X 68 |
SPEEDOMETER DRIVE:
| TACHO TORQUE 20X16 |
| CORAIL ALLOY WHEEL |
CLUTCH:
| WITHOUT CLUTCH |
GEARBOX SAFETY LOCK:
| WITH GEARBOX SHIFT LOCK |
| 195X65X15 H TYRES |
WHEELS FITTED:
| 6" RIM ROAD WHEELS |
| ALLOY WHEELS |
| Auto gearbox AL4 |
ABS:
| WITH ABS BRAKES |
REAR ANTI-ROLL BAR:
| REAR ANTI-ROLL BAR DIAM 22,5 |
ANTI-THEFT DEVICE:
| STANDARD ANTI-THEFT |
STEERING:
| UNVARIABLE POWER STEERING |
| FRONT ANTI ROLL BAR DIAM 24 |
SERVICE BRAKE:
| ELECTRONIC BRAKEFORCE DISTRIBUTION |
BRAKE TYPE:
| VENTILATED FRONT DISCS/REAR DISCS |
POWER STEERING FLUID COOLING SYSTEM:
| WITH POWER STEERING OIL COOLING |
| NORMAL SUSPENSION |
ACTIVE SUSPENSION:
| WITHOUT VARIABLE SUSPENSION |
EMERGENCY BRAKING ASSISTANCE:
| TEVES BRAKE SERVO |
HORNS:
| HORNS-HARMONY |
AERIAL:
| AMPLIFIED ROOF AERIAL |
WIPER ARM:
| FRONT BLADE WITH DEFLECTOR |
| PROTECTOR WITH CHROME RING |
SIDE MOULDINGS (DIMENSION):
| LATERAL PROTECTORS L=50 + SIDE SILL |
| CORAIL CAP |
SILL ILLUMINATION LAMP:
| SILL ILLUMINATION |
| W/O ENGINE UNDERSHELDING |
| EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION |
EXHAUST TAILPIPE TRIM:
| W/O EXHAUST OUTLET EMBELLISHER |
ENGINE BAY SOUNDPROOFING:
| BONNET SOUND-PROOFING |
REAR SCREEN WIPER:
| REAR SCREEN WIPER |
| W/O HEADLAMP WIPER |
| WITHOUT FRONT BUMPER PLUG |
BUMPER:
| BODY COLOUR FRONT/REAR BUMPER |
MUDFLAP:
| WITHOUT MUDGUARD |
LUGGAGE RACK:
| MOUNTING WITH ROOF BARS |
| FRONT FOG LIGHTS |
| HT EXT RRVW MIRROR EL INT CONTR |
| OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL |
| STEEL WHEEL + STANDARD TYRE |
| BODY COLOUR DOOR MIRRORS + HANDLES |
| DOMED DRIVER’S DOOR MIRROR GLASSS |
REAR SCREEN WASH:
| REAR SCREEN WASH |
| FIXED ROOF |
GLASS (APPEARANCE):
| TINTED |
REAR QUARTER WINDOW (TYPE):
| FIXED REAR QTR GLASS |
| ATHERMAL WINDSCREEN |
| L005 "C2" LEATHER" |
REAR HEAD RESTRAINT:
| REAR HEADREST ADJUSTABLE |
FRONT HEAD RESTRAINT:
| JOINTED FRONT HEADREST |
| SEPARATE FOLD BACK BENCH SEAT |
SUPPLEMENTARY SEAT:
| WITHOUT SUPPLEMENTARY SEAT POSITN |
REAR SEAT ARMREST:
| WITHOUT REAR ARMREST |
LOAD FLOOR MOULDING:
| WITHOUT LOAD FLOOR STRIP |
RADIO TELEPHONE:
| WITHOUT TELEPHONE PRE-EQUIPMENT |
LUGGAGE COVER:
| WITH LUGGAGE COVER |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITHOUT ALARM |
| COLD COUNTRIES |
AIR CONDITIONING:
| WITH HEATER ASSISTED CONTROL |
| GRADUATION KMS/H |
CONSOLE:
| LONG CONSOLE (SEPARATE GLOVE BOX) |
| LEFT HAND DRIVE |
REMOTE CONTROL:
| REMOTE CONTROL ASSEMBLY |
| DASHBOARD LARGE GLOVEBOX COVER, WALNUT EFFECT TRIM |
INTERFERENCE SUPPRESSION:
| RADIO INTERFERENCE SUPPRESSOR |
MISC. INT. LAMPS:
| MAP READING LAMP |
LOAD SPACE TRIM:
| TRIM BOOT + RR TAILGAT FLAP |
| STANDARD SPEEDO LOWER GRADUATION |
DOOR TRIM:
| WALNUT EFFECT DECOR |
TACHOMETER (SIGNAL CONNECTION):
| REV COUNTER CALC |
CHILD SEAT ANCHORING POINTS:
| WITHOUT CHILD SEAT MOUNTING |
| MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS |
| REMOTE RADIO CONTROL WITHOUT CD FUNCTION |
POLLEN FILTER:
| WITH POLLEN FILTER |
| WITHOUT SUN VISOR SCREEN |
| WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT |
DRIVER SEAT CONTROL:
| DRIVERS FRT SEAT MANUAL CNTROL |
FRONT PASSENGER SEAT CONTROL:
| PASSENGER FRT SEAT MANUAL CNTR |
DRIVER SEAT ADJUSTMENT:
| RECLINING DRIVER’S SEAT BACK |
| PASSENGER TILTING BACK |
FRONT SEAT ARMREST:
| FITTED WITH ARMREST |
EXTERIOR TEMP. INDICATOR:
| EXT TEMP INDICATOR |
| MOUNTING COMPACT DISC |
HANDBRAKE WARNING LAMP:
| WITHOUT PARKING BREAK INDICATOR |
| WITHOUT NAVIGATION SYSTEM |
| ELECT CONTR RR WINDOW LIFTER |
DRIVER’S WINDOW LIFT:
| SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
PASSENGER’S WINDOW LIFT:
| ELEC CNTRL PASS FRONT WINDOW LIFTER |
| DISPLAY (RADIO+CLOCK AND OR TEMP, CD) |
COURTESY MIRROR:
| DRIV OCCULT+PASS OCCULT W/O LIGHT |
OIL GAUGE:
| STD OIL LEVEL INDICATOR |
| HEATED SEAT |
| DOUBLE FRONT LATERAL AIRBAG |
PASSENGER AIRBAG:
| PASSENGER AIRBAG |
ELECTRIC WINDOW (OPERATION):
| DRIVERS SIDE ELECTRIC WINDOW AUTO STOP |
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT):
| WITHOUT REAR SHELF LOUDSPEAKER GRILLE |
ON-BOARD COMPUTER:
| COMPUTER |
| NEUTRAL FINISH INSIDE DOOR HANDLE |
COURTESY LAMP:
| FR+RE DOORS CONT - FR+RE INTERIOR LAMP |
HEADLAMP HEIGHT ADJUSTER:
| REMOTE MANUAL HEADLAMP ADJUSTMENT |
FRONT SUN VISOR:
| DRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION |
| "RM2" RDS CASSETTE AUDIO SYSTEM |
| AIR CONDITIONING |
| SPEED CONTROL |
DRIVER’S SEAT HEIGHT CONTROL:
| PARR+FR DRV HEIGHT ADJ |
INTERIOR REAR VIEW MIRROR:
AIR CON./TEMPERATURE REGULATION:
| WITH REGULATION AIRCON/TEMP |
STORAGE (OTHERS):
| TWO STORAGE BOXES IN BOOT |
CARPET COVER:
| W/O CARPETMAT |
DRIVER AIRBAG:
| DRIVERS AIR BAG |
LOAD SPACE STORAGE:
| W/O BOOT TIDY |
INTERIOR PROTECTION:
| WITH INTERIOR PROTECTION |
SWITCH:
| ELECTRONIC ANTI-THEFT KEY |
COOLANT LEVEL WARNING LAMP:
| WATER LEVEL WARNING |
| LEATHER GEAR LEVER KNOB |
EQUALISER AMPLIFIER:
| WITHOUT EQUALISER AMPLIFIER |
| SIMPLE CENTRAL LOCKING |
| LEATHER STEERINGWHEEL,4 BRANCH |
| ALTERNATOR 150 AMP |
| BATTERY L3 450 |
| STARTER MOTOR CLASS 6+ |
| WITHOUT PARTICULAR LIGHT |
MULTIPLEXING:
| MULTIPLEXING ASSEMBLY |
| STANDARD |
| NORMAL ATMOSPHERE |
FIRST AID KIT:
| WITHOUT FIRST AID BOX |
TRAFFIC SIDE:
| DRIVING ON THE RIGHT-HAND SIDE |
SIDE IMPACTS:
| DOOR WITHOUT REINFORCEMENT |
SET OF KEYS:
| 1 HF PLIP KEY + 1 SINGLE MAIN KEY |
EMERGENCY EQUIPMENT:
| W/O HELP EQUIPMENT |
SURFACE CONDITIONS:
| GOOD TERRAIN |
SPEED MONITORING:
| WITHOUT SPEED CHECK |
EMERGENCY WARNING TRIANGLE:
| WITHOUT WARNING TRIANGLE |
