Prosiłbym o sprawdzenie historii auta, bo jestem ciekaw czy faktycznie jest bezwypadkowy: Peugeot 207 HDI 90KM, VIN: VF3WA9HVC34380214 Sprawdź ten VIN na autobaza.pl ▸ pozdrawiam i z góry wielkie dzięki za informację |
nikt nic nie wie na temat tego auta???
Nie podałeś linku do ogłoszenia, a po samym numerze VIN to raczej nikt wiele więcej nie pomoże.
Poniżej to co wyszło z numeru VIN Basic Information Vehicle family: 207 (a7) Build code: 11488 76 1 0630 Warranty Start Date: 28/10/2008 Engine serial number: 10 jbar 3027991 Gearbox serial number: 20 dp45 2984172 BER: E2*2001/116*0340*09 General information PRODUCT TYPE: Car COMMERCIAL MARQUE/COMPONENT TYPE: Peugeot VEHICLE FAMILY: 207 SILHOUETTE: 3 door saloon TRIM LEVEL: X line ENGINE: Diesel turbo dv6ted4 90hp fap TRANSMISSION: Bvm5 PAINT TYPE: Metallic paintwork BODY COLOUR: Ezq - paint manitoba grey INTERIOR TRIM TYPE: Weave pachinko + tavoc2 "wu" UPHOLSTERY COLOUR: "fx" GEARBOX (CHARACTERISTICS): Be4-5l manual gearbox ENGINE (TYPE): Ev/dv OTHER BADGE, " MISC. ": Without fuller badge BADGE: Without badge Vehicle characteristics TRIM LEVEL: X line PAINT TYPE: Metallic paintwork BODY COLOUR: Ezq - paint manitoba grey INTERIOR TRIM TYPE: Weave pachinko + tavoc2 "wu" UPHOLSTERY COLOUR: "fx" GEARBOX (CHARACTERISTICS): Be4-5l manual gearbox SPEEDOMETER DRIVE: W/o tacho torque Fuel supply-Engine ENGINE: Diesel turbo dv6ted4 90hp fap DIESEL FILTER WATER DETECTOR: Without diesel filter water detector FUEL: Diesel fuel EMISSIONS STANDARD (ENGINE): Anti depollution l5 (engine) ENGINE (TYPE): Ev/dv CATALYTIC CONVERTER: 2-component platinum filter catalyser COOLING MOTOR: Radiator th : 27 - 21 dm2 brazed aluminium CRANKCASE GAS CIRCUIT HEATING: W/o heater casing gas circuit EOBD SELF-DIAGNOSIS SYSTEM: "eobd" auto-diagnostic without accelerometer DEVICE (ANTIPOLLUTION): "egr" exhaust gas recycling VEHICLE TECHNICAL DEPOLLUTION: L5 vehicle technical depollution PARTICLE FILTER: Particle filter FAN: 1 aero 2-speed 140w fan with scoop FUEL VAPOUR RETRIEVAL: Without petrol vapour recuperation INJECTION ASSOCIATED VARIANT: Mounting bosch TANK FILTER: Cithout reservoir filter STOP AND START: Without stop and start Gearbox Transmission TRANSMISSION: Bvm5 GEARBOX (CHARACTERISTICS): Be4-5l manual gearbox FINAL DRIVE RATIO: Rear axle hypoid gearset 19 x 70 SPEEDOMETER DRIVE: W/o tacho torque WHEEL STYLE: 15 inch monaco wheel DIFFERENTIAL (GEARBOX): Differential 84 RIM/TYRE SIZE: 15 inch tyre fitment TYRE (SIZE, TYPE): 185x65x15 h tyres WHEELS FITTED: 6" rim road wheels WHEEL (TYPE): Alloy wheels INFLATION PRESSURE LOSS INDICATOR: Without tyre deflation indicator GEARBOX TYPE: Gearbox be4r Suspension-Steering-Brakes ABS: With abs brakes FRONT ANTI-ROLL BAR: Front anti-roll bar diam 21 BRAKE TYPE: Ventilated front discs/rear discs STEERING TRAVEL: Steering mechanism travel 72 SUSPENSION: Normal suspension DYNAMIC STABILITY CONTROL SYSTEM: Without electronic stability program BRAKE ASSOCIATED VARIANT: Abs teves mk70 PEDAL BRACKET (TYPE): Pedal standard Body fittings HORNS: Horn standard AERIAL: Short roof aerial OPENING ROOF (APPEARANCE): Without sun roof FINISHER (SELF-ADHESIVE): Matt black rear surround trim REAR SPOILER: Assembly without rear spoiler SIDE MOULDINGS (TYPE): Lateral protector mass tinted SIDE MOULDINGS (DIMENSION): Without lateral protectors WHEEL EMBELLISHER (STYLE): Without wheel cap UNDERBODY SHIELD: Plastic protectio + foam under engine ADDITIONAL SHIELD (UNDER ENGINE): W/o engine undershelding EXT. REARVIEW MIRROR COMP. FUNCTION: Ext mirror manual-fold back EXHAUST TAILPIPE TRIM: W/o exhaust outlet embellisher ENGINE BAY SOUNDPROOFING: Bonnet soundproofing + thermal protection WINDSCREEN WIPER: Front wiper blade w/o rain sensor HEADLAMP WIPER: W/o headlamp wiper REAR SCREEN WIPER (OPERATION): Intermittent rear wiper auto operation FRONT PANEL BLANK: Without front bumper plug ROOF GLASS: Without roof window REAR TAILGATE GLASS: Fixed tailgate window OUTSIDE TEMPERATURE SENSOR: With exterior temperature sensor BUMPER: Std grl body col sport fr bumper body col std rr NUMBER PLATE: Without licence plate LUGGAGE RACK: Without roof bars FRONT FOGLAMP: Front fog lights SPECIAL HEADLAMP (DOUBLE OPTIC): Double optic lamps EXTERIOR REAR VIEW MIRROR (DRIVER SIDE): Driver’s door mirror electric control EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE): Pass ext rrview mirror non heated elect cntrl SPARE WHEEL: Emergency wheel EXTERIOR ACCESSORIES: Body coloured ext handles + ext mirror EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS): Convex exterior mirror glass SUN ROOF: Fixed roof BUMPER TRIM: Dyed bumper strip GLASS (APPEARANCE): Tinted REAR QUARTER WINDOW (TYPE): Pivoting rear qtr glass WINDOW (TYPE): Lam w/screen + side + rr toughened HANDS FREE ACCESS AND STARTING: No acces and handsfree starting Interior fittings INTERIOR TRIM TYPE: Weave pachinko + tavoc2 "wu" ANTI-THEFT ALARM: Without theft protection alarm REAR HEAD RESTRAINT: Rear headrest adjustable FRONT HEAD RESTRAINT: Front headrest adjustable REAR SEAT: Separate fold back bench seat LUGGAGE COVER: Shelf REAR SEATBELT: 3 reel 3 pt rear safe belt + unbukled warning FRONT SEATBELT: Driver + passenger seatbelt warning CLIMATE (AMBIENT TEMP): Cold countries CHILD LOCK: Without child lock SPEED GRADUATIONS: Graduation kms/h GRAB HANDLES: Pass fr handle + rear + hook RADIO EQUIPMENT: Feed aerial receiv frt speaker twt rear speaker DRIVING POSITION: Left hand drive REMOTE CONTROL: Remote control assembly LOAD SPACE LIGHTING: Glove-box lighting DASHBOARD EQUIPMENT: Mistral lion grey decor soft fascia MISC. INT. LAMPS: W/o map reading lamp INSTRUMENT PANEL (CHARACTERISTICS): 220 kmh or 140 mph graduation white dial backgroud LOUDSPEAKER: 4 fr speakers (2 tw + 2 fr) + 2 rr speakers RADIO CONTROLS: Remote radio control PASSENGER COMPARTMENT SOUNDPROOFING: 5kg bulkhead s’proof+door stop+scuttle+pedal FRONT PASSENGER SEAT HEIGHT CONTROL: Front passenger seat cushion height adjustment parallel adjustment DRIVER SEAT CONTROL: Memory ctrl drivers front seat FRONT PASSENGER SEAT CONTROL: Front passenger seat control with memory DRIVER SEAT ADJUSTMENT: Reclining driver’s seat back FRONT PASSENGER SEAT ADJUSTMENT: Passenger tilting back FRONT SEAT ARMREST: Assembly without front elbow rest ROOF CONSOLE: Without roof console COMPACT DISC: Without compact disc SATELLITE NAVIGATION SYSTEM: Without navigation system HEADLAMP BULBS: Halogen bulb REAR WINDOW LIFT: Without rear glass lift DRIVER’S WINDOW LIFT: Sequential driver’s electric window PASSENGER’S WINDOW LIFT: Elec cntrl pass front window lifter DISPLAY: Dispay (radio+clock+and or t��, cd) without memory COURTESY MIRROR: Driver’s concealable+pass non concealable no light OIL GAUGE: Std oil level indicator FITTING REAR HEAD RESTRAINT: Mount 3 rear head-rest HEATING ELEMENT: Non heated seat FRONT LATERAL AIRBAG: Thorax side + curtain airbag FOOTWELL LIGHTING: Without door sill lighting PASSENGER AIRBAG: Passenger airbag ON-BOARD COMPUTER: Computer EQUIPMENT PACK: W/o equipment pack EXTERIOR REAR VIEW MIRROR (HEATED): Heated door mirror AIRBAG DEACTIVATION: Manual airbag deactivation INTERIOR DOOR CONTROL (APPEARANCE): Int door handle grey lion COURTESY LAMP: Doors + fr courtesy light remote control DIRECTIONAL HEADLAMP: Without directional lights FRONT SEAT GUARD: Without separation grille STORAGE (DRIVING POSITION): Lower glovebox with cooling RADIO RECEIVER: "rd4/mp3" rds compact disc audio system REFRIGERATION: Single air conditioning CRUISE CONTROL: Without speed control DRIVER’S SEAT HEIGHT CONTROL: Parallel drv height adj INTERIOR REAR VIEW MIRROR: Day -night inner rear mirror - without electrochro STORAGE (OTHERS): W/o other setting boxes CARPET COVER: W/o carpetmat DRIVER AIRBAG: Drivers air bag EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS): Convex exterior mirror glass LOAD SPACE STORAGE: W/o boot tidy TUNER RADIO: Mono radio tuner INTERIOR PROTECTION: Without inner protection EXTERIOR TEMPERATURE (SCALE): Ext temp indicator celsius OBSTACLE DETECTION SYSTEM: Without obstacle detector INFLATION PRESSURE LOSS INDICATOR: Without tyre deflation indicator TRIM ADAPTATION: Gear lever knob chrome insert FLOOR MAT: W/o carpetmat EQUALISER AMPLIFIER: Without equaliser amplifier LOCKING CONTROL: Simple + automatic central locking REAR QUARTER WINDOW (TYPE): Pivoting rear qtr glass WINDOW (TYPE): Lam w/screen + side + rr toughened STEERING WHEEL: Rubber steering wheel STORAGE SPACE LOCKS: Glove-box without locking FAN: 1 aero 2-speed 140w fan with scoop AMBIENCE PACK: Without ambiance pack DRIVER’S KNEE AIRBAG: Without driver’s knee airbag AUDIO PACK AUXILIARY SOCKET: 1 audio rca socket Electrical ALTERNATOR: Alternator 150 amp HORNS: Horn standard BATTERY: Battery l2 400 REMOTE CONTROL: Remote control assembly STARTER MOTOR: Class 6 starter motor LOAD SPACE LIGHTING: Glove-box lighting SPECIAL LIGHTING: Without particular light MISC. INT. LAMPS: W/o map reading lamp EXT. REARVIEW MIRROR COMP. FUNCTION: Ext mirror manual-fold back CEN. LOCKING REM CONTROL FREQUENCY: Locking remote control frequency 433.92 mhz heterodyne HEADLAMP BULBS: Halogen bulb MULTIPLEXING: Multiplexing assembly can can FOOTWELL LIGHTING: Without door sill lighting COURTESY LAMP: Doors + fr courtesy light remote control FRONT FOGLAMP: Front fog lights DIRECTIONAL HEADLAMP: Without directional lights SPECIAL HEADLAMP (DOUBLE OPTIC): Double optic lamps RADIO FREQUENCY: Western europe radio frequency Component manufacturers BRAKE ASSOCIATED VARIANT: Abs teves mk70 INJECTION ASSOCIATED VARIANT: Mounting bosch Miscellaneous ATMOSPHERIC CONDITIONS: Normal atmosphere DRIVING POSITION: Left hand drive RADIO HEADPHONE SOCKET: Without accessories socket TRAFFIC SIDE: Right hand drive SET OF KEYS: 1 hf plip key + 1 single main key EMERGENCY EQUIPMENT: W/o help equipment SURFACE CONDITIONS: Good terrain EXTERIOR ACCESSORIES: Body coloured ext handles + ext mirror SPEED MONITORING: Without speed check SLAVE CONTROL UNIT: Bsi + com 2005 4-position ring |
linku nie mam ponieważ, auto nie jest wystawione nigdzie w internecie, a tak apropo to co by dał link ze zdjęciami? a jakie jeszcze dane są potrzebne żeby jakoś sprawdzić czy auto ma jakąś historię wypadkową?
głównie sprawdza się po numerze VIN (głównie w 90% auta z USA i Kanady), a po zdjęciach czasami od razu widać, że auto było np. walone i lakierowane.
OK dzięki za informację
