TEMAT: Proszę o informacje z dekodowania winu
Proszę o informacje z dekodowania winu 2012/07/17 14:16 #27699
  • karbit
  • karbit Avatar
prosze o pomoc o zdekodowanie vinu JTHBE262X75016393 Sprawdź ten VIN na autobaza.pl ▸
Odp: Proszę o informacje z dekodowania winu 2012/07/18 21:08 #27733
JTHBE262X75016393
JTHBE262X75016393
Japan
Iwata Plant
Lexus
IS
Wersja:
XE20
Sedan 4D
Drzwi:
4-door
3.5L V6 24V DOHC
Napęd:
front
Gasoline
C11E:
Child safety door locks
P5ED:
Power door locks
V452:
Vehicle anti-theft
A364:
Abs brakes
E7CA:
Electronic brake assistance
T643:
Traction control
V030:
DCC4:
Driver airbag
F4FC:
Front side airbag
PA4E:
Passenger airbag
S710:
Side head curtain airbag
F46D:
First aid kit
TD1D:
Trunk anti-trap device
KA70:
Keyless entry
AFD8:
Air conditioning
S7E4:
C469:
Cruise control
TA7F:
Tachometer
T008:
Tilt steering
TC5A:
Tilt steering column
L272:
Leather steering wheel
SF2A:
TA8A:
Telescopic steering column
T114:
Tire pressure monitor
T9EA:
Trip computer
AC08:
Am/fm radio
C354:
Cd player
C42A:
Cd changer
DE19:
F3F3:
Front power lumbar support
L07A:
Leather seat
P5E9:
Passenger multi-adjustable power seat
C39A:
Cargo area tiedowns
P7AD:
Power sunroof
M0DB:
Manual sunroof
AAB8:
Automatic headlights
D835:
Daytime running lights
F98D:
Fog lights
F4AE:
Front air dam
AA42:
Alloy wheels
P38E:
Power windows
HC6B:
Heated exterior mirror
E49E:
Electrochromic interior rearview mirror
P673:
IC14:
Interval wipers
RE3B:
Rear window defogger
*AD9:
**ALL STANDARDS ARE 2007 UNLESS OTHERWISE NOTED**
4E5B:
4-wheel anti-lock brake system (ABS)
D724:
Driver & front passenger airbag (SRS)
F279:
Front/rear side curtain airbags (SRS)
F0BE:
Front seat-mounted side airbag (SRS)
A24C:
All-position 3-point seat belts
FCF9:
Front/rear outboard seat belts w/force-limiting pretensioners
H249:
Height-adjustable front shoulder belt anchors
EB9D:
Emergency locking retractor (ELR) for all seating positions
A6C0:
Automatic locking retractor (ALR) for front/rear passenger seats
CB5A:
Child restraint seat (CRS) w/top tether anchor brackets
T452:
Traction control (TRAC)
VE8B:
Vehicle dynamics integrated management (VDIM) w/cutoff function
CF8A:
Collapsible steering column
I673:
Impact-dissipating soft upper headliner & pillars
F86D:
Front/rear door side-impact beams
F73B:
Front/rear crumple zones
OBA5:
One-piece color-keyed front/rear bumpers
L27D:
Low grille w/color-keyed front airdam
P017:
Projector bulb headlamps w/headlamp off delay
FD85:
Front fog lamps
L030:
LED lights-inc: brake lights, tail lights
U2C4:
UV & infrared ray-reducing glass w/acoustic windshield glass
CBA0:
Color-keyed heated mirrors w/puddle lamps
V72E:
Variable intermittent wipers w/mist cycle
36CB:
3.5L DOHC 24-valve direct injection V6 engine-inc: dual variable valve timing w/intelligence (VVT-i)
6CC7:
6-speed electronically controlled automatic transmission w/intelligence (ECT-i), OD
R323:
Rear wheel drive
D54E:
Double wishbone front suspension-inc: high-mount upper arms, coil springs
M6C6:
Multi-link rear suspension-inc: high-mount upper arms, coil springs
F6E8:
Front/rear gas-filled shock absorbers
FAC2:
Front/rear stabilizer bars
P6A4:
P225/45VR17 all-season front tires
PA1E:
P245/45VR17 all-season rear tires
16B2:
17" x 8" 10-spoke aluminum alloy wheels
T89C:
Temporary spare tire
S0CF:
Speed-sensitive electric pwr steering
4C15:
4-wheel pwr ventilated disc brakes w/tandem brake booster
E4B7:
Electronic brake force distribution (EBD)
B065:
Brake assist (BA)
D569:
Dual stainless steel exhaust
TE5A:
Tool kit
S488:
Semi-analine leather seat trim
1751:
10-way pwr front bucket seats (2006)
R7F0:
Rear bench seat w/trunk pass-through
CBDA:
Center console-inc: front armrest, (1) front cupholder, (2) rear cupholders, storage box
1EE9:
1-piece cut pile carpeting
C39E:
Carpeted floor mats
MA13:
Manual tilt/telescopic steering wheel w/paddle shifters
OC24:
Optitron gauges-inc: 160-mph speedometer, 8000-rpm tachometer, fuel level, coolant temp
W5A6:
Warning lights-inc: battery, oil level, seat belt, brake, airbags, engine, oil pressure, low fuel, tire slippage (w/TRAC)
I42E:
Indicator lights-inc: door ajar, TRAC off, headlamp on, high beam, cruise control, fog lamps on
T138:
Tire pressure monitoring system
SB08:
Scheduled maintenance indicator light
D2DB:
Digital odometer w/(2) trip meters
O704:
Outside temp gauge
DA64:
Digital clock
PD6F:
Pwr windows-inc: auto-up/down, jam protection
PFA6:
Pwr door locks-inc: anti-lockout, speed-sensitive auto lock/unlock
RE99:
Remote keyless entry-inc: multi-function remote, lock, 2-stage unlock, trunk, panic feature, adjustable volume, rolling code
IF69:
Illuminated trunk & fuel filler door release
RFD0:
Retained accessory pwr for windows
L6D5:
Lexus personalized settings (LPS)
RAB9:
Remote keyless entry system-inc: lock, two-stage unlock, trunk open, panic feature, volume-adjustable tone, rolling code
H117:
HomeLink programmable garage door opener
VB5E:
Vehicle theft-deterrent system w/engine immobilizer
A20D:
Automatic climate control-inc: dust filter, pollen filter, speed & air flow indicators
HED9:
HD rear window defogger w/timer
PA16:
Premium 194-watt sound system-inc: AM/FM stereo, in-dash 6-disc CD changer, automatic sound levelizer (ASL), auxiliary audio input, (13) speakers
R5A4:
Rear glass-imprinted antenna w/FM diversity antenna
C6A5:
Cigarette lighter w/front ashtray
(CBC:
(1) cupholder behind shift lever
MCA7:
Metallic-finish interior accents
EFBF:
Electrochromic rearview mirror w/compass
SE29:
Sun visors w/vanity mirrors
(7EA:
(2) front/(2) rear assist grips
L7EA:
Lighting-inc: door courtesy, glovebox, trunk, front/rear dome, LED map
F2B5:
Front seatback pockets
RC60:
Retractable coat hooks
GALERIA # 0
